Bronco II Ford Bronco II
85 Bronco II knocking??
Old Mar 24, 2004 | 02:58 PM
meeseaz's Avatar
meeseaz
Well, I just bought this 85 for 700.00. There is a wierd knocking sound comming from the lower engine. I have tuned it up, changed the oil and adjusted the valves but it is still there. I have good oil pressure so can it be my main bearings?? Could it be an exhaust leak??
Any help would really be appreciated...
Thanks Mike
Old Mar 24, 2004 | 10:33 PM
goalscorer2's Avatar
goalscorer2
ummm if its like a clicking sound everytime you let the clutch in and sit at neutral it might be the spindle of the tranny isn't being happy with it's female counterpart on the bottom/back of the engine. other than that i ain't got a clue
Old Mar 27, 2004 | 12:12 PM
Russ86B2's Avatar
Russ86B2
Crankshaft bearings, you can check for allot of play by pulling and pushing on your crankshft pulley. If it moves back and forth...you've got to do some work.
Old Mar 27, 2004 | 05:40 PM
chadscanadian's Avatar
chadscanadian
I had the same problem, I was told it was probably my sterring arms mounts, but one day the problem just disapered. I tried replacing the u joints but that didn't fix anything. But i wonder if it has something to do with your 4x4 becuase after the sound diapered on my truck my 4 wheel started to always pull to the right.
