1987 Bronco II - No Horn or Cruise Control
I have recently acquired this '87 Bronco II. The horn and cruise control do not work. I replaced the fuse but they still do not work. I believe it is the relay , which I have already purchased but cannot find it on the truck.
Does any one know where it is located?
Thanks
Thanks
I'm looking at the wiring diagram for my 87 & fuse 16 supplies voltage to the cigarette lighter (is it working) and to the horn relay (in the steering column) The horn relay supplies voltage to the "on" cruise switch on the steering wheel thru a "voltage supply brush" Do you have voltage at the on swtch? If not the relay or the brush is shot. Fixing this would be very simple if you had the "electrical & vacuum troubleshooting manual" from www.helminc.com Or take KenOO up on his offer for the wiring diagram.
Rose Clifford
35
01-31-2018 02:30 PM
Mikey Cash
08-02-2013 08:40 PM
