P1780 code - trans ctrl switch???
Old Sep 27, 2015 | 11:04 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by johnny28
But what could be the switch?
I don't understand this question.
Old Sep 27, 2015 | 11:22 AM
johnny28's Avatar
johnny28
Which switch would be?
Old Sep 27, 2015 | 04:38 PM
Mark Kovalsky
The code indicates the switch on the end of the shift handle. The code set because you didn't press the button on that switch during the key on engine running test.
Old Sep 27, 2015 | 08:00 PM
johnny28's Avatar
johnny28
but u say that the problem in the transmission is that simple process which u siad up here?
Old Sep 27, 2015 | 10:48 PM
Mark Kovalsky
I didn't say what the problem is. I just know that the code you had doesn't cause a problem. I read what you wrote, but I don't understand what you're saying is your problem.
Old Sep 28, 2015 | 01:19 AM
johnny28's Avatar
johnny28
Sorry man i wasn't clear. My expedition 2005 5.4L, the computer show me the code p1780 transmission control switch. The issue in truck is like the presure in the throttle converter doesn't increase, so whenever I push the acelerator, the rpm go up but the truck moves slowly. You can see the rpm go up and the truck moving slow. In conclusion, I would need to know if anyone herad about this prooblem or whether know which would be the problem in order to fix it. Thank you very much.
Old Sep 28, 2015 | 03:17 AM
Skauber's Avatar
Skauber
Let me see if I can make it more clear. You start it up, engine runs normally and revs normally. Put it in Drive (D) and hit the accelerator and the engine revs, but the truck hardly moves?
Sounds like transmission slipping. Have you checked the transmission fluid? Is it at the correct level and is it bright red and no burnt smell?
When you put it in D, do you feel that the truck goes into gear? (slight drop in engine rpm, and a subtle kick in the truck). Does it reverse normally (try "R")? Is there any difference if you select 1 or 2 rather than D?
Ignore the code P1780, it only shows that the O/D switch wasn't pressed during a test, as Mark already told you. It has nothing to do with the issues you describe.
Old Sep 28, 2015 | 07:01 AM
johnny28's Avatar
johnny28
Exactly it is like transmission slipping, the fluid is perfect in level and color, my reverse works perfect but no 1 and 2
Old Sep 28, 2015 | 07:34 AM
Skauber's Avatar
Skauber
Ok, for me, it sounds like you need to rebuild the transmission. Perhaps worn out forward clutch or something, though I'm not a transmission expert. Perhaps Mark has an idea of what is going on?
Old Sep 28, 2015 | 08:17 AM
Mark Kovalsky
My guess from this information is that the trans is stuck in a higher gear, it's not starting in first gear. What happens if you move the shifter to 1 to get started? Is it better?
Old Sep 28, 2015 | 06:23 PM
johnny28's Avatar
johnny28
drive, first, or second is the same. but I feel when move the handle to first or drive that gear move, like i feel that the truck is un drive or first but still don't move fast, is like as the truck is always in 3
Old Sep 28, 2015 | 06:26 PM
johnny28's Avatar
johnny28
what do u think guys could be the neutral switch which is located outside of the transmission and where the cable goes?
Old Sep 29, 2015 | 09:08 AM
  #28
alloro's Avatar
alloro
How high do the RPMs go when you attempt to move?
Old Sep 29, 2015 | 03:02 PM
  #29
Mark Kovalsky
No, I don't think this could cause your problem.
Excellent question! I'm very interested in the answer.
Old Oct 2, 2015 | 07:28 PM
  #30
johnny28's Avatar
johnny28
hi sorry but i was keeping pretty busy, the rpm go high i really do't know exacly but go more than 3500 or 4000 rpm
