Rev limiter
I was talking to a guy the other day about making a rev limiter for a '71 460. Something that would cut out 1 cylinder on each bank when a certain RPM was achieved.
If I'm not mistaken, grounding out a plug wire will stop it from firing. Question is, how would you ground it out only sometimes?
I thought of using a normally-open relay with a wire from the plug to one side, and the other side to ground. When the relay is closed, the plug grounds out. I don't know if that would ground out all the time though. Like if the spark would jump the gap of the open relay.
Anyone have a better idea or know if this is possible?
Thanks in advance!
Kevin K.
What kind of circuitry are you going to use to select the proper rpm?
Best to save a little money and buy one that fits on the low voltage primary side of the ignition.
If I cut it out on the primary side, wont it kill ALL the plugs?
Kevin K.
