trailer hook up wiring
Old Mar 21, 2004 | 12:47 PM
dougford's Avatar
dougford
I have a 99 ford F150 truck. When i hook up the 4 to 6 pin connector to the trailer the LH trailer brake and turn lights do not flash or ilumniate when brake pedal is pushed or signal turned on. The RH side works fine. i checked for voltage on the truck side but am not getting voltage for the LH side. Is there a relay that controls this voltage? I have checked fuses in cab and they appear to be okay. Trailer side is okay so am trying to troubleshoot the truck side?
Old Mar 21, 2004 | 01:49 PM
Mil1ion's Avatar
Mil1ion
Is this a Ford plug or aftermarket plug ?
Old Mar 21, 2004 | 02:10 PM
dougford's Avatar
dougford
I have a 4 pin connector on the truck that is a ford production part. I checked for voltage here also. I get the RH turn and brake but not the LH turn brake?
Old Mar 23, 2004 | 05:45 PM
ncdiver's Avatar
ncdiver
Lights
I have a 2002 expedition and have the same problem as you but it is the right side that gives me the same problem as you.. All factory wiring too. Wish I had a good answer.
ncdiver
Old Mar 24, 2004 | 09:01 AM
KJKozak2's Avatar
KJKozak2
Are these 4-wire Ford connectors that you guys have the larger ones made for seperate turn/brake lights? Or are the truck's turn signals and brake lights the same bulb?
Kevin K.
Old Mar 24, 2004 | 06:18 PM
ncdiver's Avatar
ncdiver
Kevin K.
Mine is factory original 4 wire. Left side works great right side running lights work but turn and brek do not work on the trailer or when I ck voltage at the harness under the car.
Old Mar 25, 2004 | 11:00 AM
krazdndenver's Avatar
krazdndenver
I install hitchs at work and if I remember ford has a seperate circuit for trailer wiring. There are two fuses i think that power these circuits. I would look for these fuses either inside the cab or under the hood in the main distribution center. Hope this helps.
Robert
72 F100 Ranger XLT W/ 86 5.0L EFI W/ AOD
www.geocities.com/krazdndenver
