Oil usage. THE TRUTH please?
Old Mar 25, 2004 | 09:03 PM
believer45's Avatar
believer45
This is the truth. Mine has not used any oil between oil changes in the 60,000 plus miles I have had it. None, nada, zilch, does not move off the full mark. Oil change interval is 5000 miles. Truck has 203,445.9 miles on it at last fuel up a couple hours ago about 35 miles from home.
Dave / Believer45
Last edited by believer45; Mar 25, 2004 at 09:04 PM. Reason: Correct typographical error.
Old Mar 25, 2004 | 09:07 PM
c_rossman's Avatar
c_rossman
I am sure it burns some, just not noticable. See there is always a thin film of oil the oil ring leaves behind to lubricate the compression rings. This oil will get burned off eventually. IF oil doesnt get by the oil rings then the cylinders wont last very long.
Old Mar 25, 2004 | 11:25 PM
hughesm1's Avatar
hughesm1
I burned a couple quarts every 4000 miles in the first 25000 miles, since then I've noticed a consumption rate of 1 qt. every 4000.
Old Mar 26, 2004 | 04:15 AM
Quadzilla's Avatar
Quadzilla
Like many, mine doesn't burn enough for me to add any oil between oil changes.
EcoboostKev
17
Nov 26, 2014 07:52 PM
ALedbetter1
Jun 11, 2013 12:31 AM
BigRedBlur
2009 - 2014 F150
16
Jun 19, 2011 08:08 AM
97ExpGuy
Modular V8 (4.6L, 5.4L)
May 18, 2009 07:38 PM
79CEEJAY
Dec 25, 2006 08:21 PM
