1978 - 1996 Big Bronco
transfer case 1989 broncoxlt
Old Mar 24, 2004 | 09:35 PM
Jdenninger's Avatar
Jdenninger
all the time. it's on the spindle for the rear axle
Old Mar 24, 2004 | 09:45 PM
mustangman65_79's Avatar
mustangman65_79
hmmmmmmmmmmmmm, howould u know if it went out? I have 156,000 miles on mine, stock
Old Mar 24, 2004 | 09:48 PM
Jdenninger's Avatar
Jdenninger
it would seize and something would most likely snap
Old Mar 24, 2004 | 09:50 PM
Jdenninger's Avatar
Jdenninger
the only time it isn't pumping and the truck is running is in neutral on the xfer-case
Old Mar 24, 2004 | 09:53 PM
mustangman65_79
so, it's one of those, it's not broke, till it's really broke.
No way to find out before hand hu?
Old Mar 24, 2004 | 09:54 PM
Jdenninger's Avatar
Jdenninger
not without cracking the cse open as far as i know.
Jeff
89 bronco XLT 5.0
Old Mar 24, 2004 | 09:55 PM
mustangman65_79
guess I'll just wait then-lol
Old Mar 24, 2004 | 09:56 PM
Jdenninger's Avatar
Jdenninger
or crack it open and replace the bracket that usually goes bad. You do a lot of offroad?
Old Mar 24, 2004 | 09:57 PM
lakahahahman's Avatar
lakahahahman
even if i put my transfer case shifter into nuetral it is still engaged in low
Old Mar 24, 2004 | 10:00 PM
Jdenninger's Avatar
Jdenninger
your reduction fork is too worn or has snapped and cannot take the reduction gear out of low. xfer case needs to be rebuilt. Its not too difficult. get a new reduction fork, oil pump, oil pump hose and gasket for between the tranny and xfercase. Also need 3-4 qts of Mercon Tranny fliud and a decent set of tools.
Old Mar 24, 2004 | 10:09 PM
lakahahahman
so i am assuming that i would need a torque wrench
is it in inch or foot pounds would i need some type of instruction booklet
i have a haynes book for big ford truck and bronco's
would it be in there
Old Mar 24, 2004 | 10:22 PM
mustangman65_79
not a lot, mostly on road
Old Mar 25, 2004 | 04:50 AM
  #28
Jdenninger's Avatar
Jdenninger
then you probably are ok
Old Mar 25, 2004 | 04:52 AM
  #29
Jdenninger's Avatar
Jdenninger
Yes you would need a torque wrench. the torque specs are in the haynes manual in hte chapter for the xfer case
Old Mar 25, 2004 | 10:38 PM
  #30
steell's Avatar
steell
That oil pump bracket wears through the ridge on the case regardless of whether you go off road or not. Personally, I think anyone that has a 1356 with over 100k on it ought to open the case and weld a extension on that piece, to keep it from wearing through. Save some money that way.
