Replacing Plugs
Old Mar 23, 2004 | 05:55 PM
ncdiver's Avatar
ncdiver
Replacing Plugs
I have a 2002 expedition, 5.4 eng and I have found that each plug has its own coil and the back two on the right and left side will be a real pain to get to. I called ford and they want 350.00 to change the 8 plugs.
1.) Does anyone have a good way to changing them and what plugs they recommend?
2.) I purchased Bosh Platinum but from what I have read they have been causing probs with other exp edition owners.
Thanks,
ncdiver
Old Mar 23, 2004 | 06:25 PM
4x4lowandslow's Avatar
4x4lowandslow
Where you at in NC?
Old Mar 23, 2004 | 07:40 PM
ncdiver's Avatar
ncdiver
NC
in Morehead city
Old Mar 25, 2004 | 05:30 PM
4x4lowandslow
I'm in Morehead also and I'd be glad to look into changing the plugs for you before you drop $350 on a plug change.
Old Mar 26, 2004 | 08:40 PM
Phinxter's Avatar
Phinxter
Just to keep you out of trouble stick to this rule of thumb for sparkplugs:
Fords- Motorcraft 1st and Autolite 2nd
GM- AC/Delco
Mopar- Champion
Jap cars- NGK
One other thing, If possible only buy these plugs at a dealer or reputable supplier (not Advance, Autozone, Walmart etc) What you get from other places are factory seconds, not to say they are electrically 'bad' but for some reason the were rejected and not perfect. Every mechanic I know (and I know alot) say don't use Bosch they are 'junk'.
Old Mar 26, 2004 | 09:06 PM
Mil1ion's Avatar
Mil1ion
This Thread will be moved to the 5.4 L engine forum
Old Mar 28, 2004 | 10:32 PM
brown 4x4's Avatar
brown 4x4
I did plugs on a 5.4L a couple months ago. For the drivers side I ended up lifting the fuel rail up a couple inches to get access. Then there's one screw on each coil, pull it out, and there's your plug. A long extention is needed to get down to the plug.
