Sponsored by: Real Truck
Another noisey V10
Old Jun 6, 2000 | 03:57 PM
bas's Avatar
bas
Another noisey V10
I have a 2000 F250 crew cab V10. It has 1000 miles on it. Since I drove it off the lot, (6 week wait) it makes a loud "rattling" or "pinging" sound at 2500 rpm under load. That is while accelerating. Sounds like an old time exaust leak. It does not make the noise if it is just being reved up in nuetral or drive. Fact is I had a 99 V10 on a extra cab F250 and it purred like a kitten.
I brought it to the dealer and they said that it defenitley was not an exaust leak but Ford has a bulletin out on it (ssm#13519) that says the noise does not cause driveability issues. Obviously they had no clue what is causing it.
It sounds terrible as if there is no oil going to the valve train. It is not improving as it breaks in. However, it does seem to have good power but I am afraid to tow my boat as this would be the RPM range under load I would tow in. Is it the exaust system or the valves? does any one know?thank you.
Old Jun 6, 2000 | 05:33 PM
2000sprdty's Avatar
2000sprdty
Another noisey V10
Same here mine makes the same noise and I have only 550 miles on her.I just think it is normal ( I hope)
2000superduty
Old Jun 6, 2000 | 07:11 PM
wawii's Avatar
wawii
Another noisey V10
Reports I've read state that it's a "standing sound wave" in the exhaust y-pipe.
Thanks,
Will
2000 F-250 SD Crew Cab, Short Bed, Lariat, 4X2, V-10, Auto, 3.73LS
Old Jun 6, 2000 | 09:10 PM
bas's Avatar
bas
Another noisey V10
Thanks for the reply, I have heard about the "y" pipe but I have also heard about guys getting new engines because of this. Anybody else hear that? If it is the "y" pipe, can it be fixed? Thanks, Brad.
Old Jun 7, 2000 | 10:23 AM
rob_n_houston's Avatar
rob_n_houston
Another noisey V10
I believe the engine replacement refers to the piston slap problems on some the v-10 and v-8 engines. The problem was fixed on any engine made after April 15, 1999. I to was worried about this after purchasing my 1999 truck (used). My engine date happens to be April 28, 1999. No PS in mine.
I also have the Y pipe vibration. Always between 2100 and 2300 rpm during normal driving. I plan on trying to add some weight, hose clamps, etc to see if I can direct the sound waves in a different pattern. It's really ruins the sound/feel of the v-10 which (having 2 more cyl) runs smoother than a v-8.
Rob
1999 F-250 SD CC V-10 4X4 XLT Lariat Red clear coat...newly added custom built multi mount winch system
Old Jun 7, 2000 | 03:17 PM
bas's Avatar
bas
Another noisey V10
Interesting info you gave. Is your noise ike a "rattle" or "ping" while pushing it at about 2500 rpm? Let me know if your ideas help. Thanks alot. Brad
F250 SD, 2X4, CC V10, Wedgewood
Old Jun 8, 2000 | 06:30 AM
Weirden's Avatar
Weirden
Another noisey V10
Is there any good news about the V-10?
Mine is still new, 1000 milse, no problems. I would like to hear about some good ezperiences if any one would like to let us know.
Thanks,
2000 SD V-10 4X4 SC LB 4.30 auto
Old Jun 8, 2000 | 06:20 PM
rons's Avatar
rons
Another noisey V10
>the V-10?
>know.
>Thanks,
>4.30 auto
I've been driving a 1999 F250 SD V-10 4X4 Lariat for the past 2 years (one of the first 99 models made), and that V-10 has been absolutely great! I just traded it on a brand new 2000 F350 SD, same drive train, and so far, the Triton V-10 is as smooth and quiet as my first one. I have found this engine to be one of the finest gasoline truck engines I've yet to encounter. My uses included highway hauling, light off-roading, snow-plowing, and occasional towing.
Regards,
Ron S.
2000 F350 SD SC 4X4 V10 3.73 LSD 4X4 auto
Old Jun 8, 2000 | 07:57 PM
bas's Avatar
bas
Another noisey V10
I also owned a 99 F250 SD w/ a V10. it was wonderful. I tow a 5500 lb. boat and it was as smooth as silk. I now have a 2000 and it too is wonderful. It actually feels like it might have more power than the '99. Just that darn noise..... Brad.
Old Jun 15, 2000 | 07:41 AM
goodfoot's Avatar
goodfoot
Another noisey V10
V10is a great motor. I've got over12,000 miles. Not a problem 1 with the engine. Now that the rear end is fixed I'm gittin' 12 to a little over 13 mpg on regular gas with a K&N filter. I used to be a chevy guy, solong GM!
Old Jun 18, 2000 | 09:31 PM
fishinbum's Avatar
fishinbum
Another noisey V10
Old Jun 24, 2000 | 09:21 PM
caliv10's Avatar
caliv10
Another noisey V10
I have a 2000 crew cab 4x4 v10 and it too had a ping sound from the exhaust, when it was new it was loud, it only has 650 miles on it and the noise is just about gone, so I guess it goes away after break in.
Kennedy2
Modular V8 (4.6L, 5.4L)
116
Mar 5, 2025 08:58 PM
geniusloerts
Apr 24, 2016 08:16 PM
StewB
May 31, 2015 08:11 PM
120mm Jedi
Nov 12, 2014 11:55 AM
miottimouse
Aug 9, 2011 10:40 AM
