General Automotive Discussion
gear oil
Old Mar 23, 2004 | 11:18 AM
hendrix89's Avatar
hendrix89
Question gear oil
Question:
I bought one of those neat chrome differential covers. Here is the question I heard to stray away from the 75w-140. It has to do with not absorbing water?? anyway should I use a 75w-90w gear oil instead????? and do I need to buy a gasket, I heard just use some of that blue sealant.
Thanks
William
Katy, Texas
Old Mar 23, 2004 | 12:29 PM
superrangerman2002's Avatar
superrangerman2002
Re: gear oil
Originally posted by hendrix89
Question:
Thanks
William
Katy, Texas
Welcome to FTE!
This question is prolly better answered in the Oil and Lubrication Forum, but that's ok.
I don't know where you've heard this from, but it sounds like it may have come from one of those checkout commandos at the local Autozone.
Absolutely stick with the 75-140 oil, as I've learned the hard way that the 80-90 leaks like water in a strainer at operation temps in the newer ford rears.
That little mistake I made almost cost me my rearend, but luckily I caught it soon enough and it only cost me a set of rear brake pads and 3 seals (pinion seal and axel seals).
Plain ole RTV is all you need to seal the rear end up, but make sure you scrape all the old stuff off, and let the diff set for an hour after you bolt up the new cover, before you put fresh oil in.
Old Mar 23, 2004 | 12:33 PM
hendrix89's Avatar
hendrix89
Do I have to get the gear oil from Ford? I cannot find the correct oil. I have a limited slip gear. any suggestions what brand?? I looked up Pennzoil. They everything but the weight.
Old Mar 23, 2004 | 12:41 PM
hendrix89's Avatar
hendrix89
Thank you for the help and thoughts. Nice place to be for info!!!
William
hendrix89
Old Mar 23, 2004 | 12:43 PM
Big Orn's Avatar
Big Orn
I use Mobil 1 synthetic with friction modifier, but the Ford recommended fluid is just as good.
What year model is your truck?
Old Mar 23, 2004 | 12:45 PM
hendrix89's Avatar
hendrix89
My truck is a 03 supercab with the 4.6
