high speed vibration
Old Mar 23, 2004 | 08:08 AM
vbdig's Avatar
vbdig
I just purchased a 392 stroker motor from Ford Racing. It came with flywheel and vibration damper. It has terrible vibration above 4500 rpm. A resonant vibration, not a engine miss. I know that the flywheel is supposed to be balanced, I did remove it to install a backing plate for the bellhousing, can the flywheel go on wrong? I believe the bolts are in a pattern that does not allow this but something is very wrong. I have driven it for 300 miles, and I just noticed that I have very low oil pressure now. I think I may have screwed up.
Old Mar 23, 2004 | 07:25 PM
fordeverpower's Avatar
fordeverpower
call them up and them them of the problem!
Old Mar 24, 2004 | 09:19 AM
beartracks's Avatar
beartracks
Sounds like something wrong on the mains or rod bearings. I wouldn't drive it untill I was sure. You might throw a rod and have even bigger problems
Old Mar 24, 2004 | 10:46 AM
vbdig's Avatar
vbdig
I found it, the pilot bearing pushed into the crank leaving no support for the input shaft and no centering for the clutch. Ruined crank and bearings. Pretty dumb
Thanks
bandeto44
Jan 23, 2014 05:49 AM
01f350
Jan 4, 2010 06:51 PM
MustangMatt96GT
Feb 28, 2009 07:30 PM
rhetor
Feb 8, 2008 05:59 PM
kellar
Engine Swaps
Mar 2, 2007 05:45 AM
