electrical issue
Old Mar 23, 2004 | 07:14 AM
dillgo's Avatar
dillgo
Question electrical issue
97 Explorer XLT 4d has some type of electrical isssue. Sometimes the rear left window won't roll down, the radio can be turned off and come on, the blinker buzzes sometimes when you try and use it and some mornings it wil turn over for a minute or more and won't start. It usually eventually starts, and when it does, it runs fine. I read about cleaning the IAC, but that sounds like something to do if it is idling rough. I don't know if the electrical issue is affecting the hard start as well. Any ideas? Thanks
Old Mar 23, 2004 | 05:50 PM
78fordman's Avatar
78fordman
Sounds like a metled siring harness, or some striped wires. Open up the wiring loom and look.
Old Mar 24, 2004 | 06:37 AM
dillgo's Avatar
dillgo
wiring loom
Thanks, 78Fordman. The wiring loom is under the hood? Then I look an exposed or stripped wire?
