offset piston pins
Old Mar 23, 2004 | 05:13 AM
muscletruck7379's Avatar
muscletruck7379
offset piston pins
i was reading an article and it was talking about offset pins in 302's and swapping the pistons around to to add about 10-15 horse. said they were about 0.030 offset, i was just wondering if anybody knew more on the subject.
Old Mar 24, 2004 | 05:08 PM
RTM's Avatar
RTM
Well I would think the only thing you gain from this is a higher compression ratio and that could be had by shaving the heads or installing bigger pistons to begin with.
You would also have to be very careful that the piston top does not hit the bottom of the head.
Old Mar 24, 2004 | 05:54 PM
daerhldgs2's Avatar
daerhldgs2
the pins are offset from side to side to help the thrust angles on the pistons and improve sealing of the rings and hence better oil control and wear.If they were offset vertically you would encounter clearance problems with the head and valves.
Old Mar 25, 2004 | 10:42 PM
GypsyR's Avatar
GypsyR
Yes, pistons are offset from the factory. They are marked with and arrow so they will be placed facing forwards. Some time back some folks discovered that installing them "backwards" was worth a few horsepower. It also caused piston rattle on startup and tended to crack and break off.
A useful trick for certain types of racing, but not a good idea for any other purpose. Expect much shortened engine life doing this.
Old Mar 26, 2004 | 04:14 AM
RTM's Avatar
RTM
I never heard of this. Learn something new every day.
