1978 - 1996 Big Bronco
very weird vibration
Old Mar 22, 2004 | 09:28 PM
crazed87bronco's Avatar
crazed87bronco
well today i thought id take some time and drive to get some gas in the bronco i havent driven it for about 3 weeks or so because of engine troubles with my new bbk throttle body so as soon as i hit the road there was a very wierd vibration in the rear of the bronco i thought it was not a big deal as soon as i let off the gas it go away as soon as i press the gas the vibration comes back what could be the problem the 1 rear wheel does wobble alittle can this be because a shot bearing sorry for the long post any help needed
Old Mar 23, 2004 | 02:12 AM
77redf250's Avatar
77redf250
most driveline vibrations are from worn u-joints or cv(double cardan) joints. usually wheel bearings in the rear just make a lot of noise with a semi floater diff. i'd check all the universals asap. wheel wobble is most likely from a bent rim or axle or possibly loose lugnuts. good luck
Old Mar 23, 2004 | 07:03 PM
crazed87bronco
it was fine when i last drove it 3 weeks ago but this time i drove it the thing shook alot can the u joints wear out just like that
Old Mar 23, 2004 | 08:37 PM
mustangman65_79's Avatar
mustangman65_79
sounds like u-joints
Old Mar 23, 2004 | 09:14 PM
Sudsrat's Avatar
Sudsrat
ditto...
BroncoBoss351
Nov 28, 2005 01:32 AM
GucciSock
Nov 9, 2003 08:47 AM
zeindog
Feb 2, 2001 09:01 PM
