Aerostar Ford Aerostar
center console removal
Old Mar 22, 2004 | 08:16 PM
jeff_67cougar's Avatar
jeff_67cougar
Question center console removal
Does anyone know how to remove the stock center console? It looks like it might be bolted in from under the van.
Old Mar 22, 2004 | 10:39 PM
rebocardo's Avatar
rebocardo
Bolts in from the inside 100%, I know that.
Been about six years since I did one. I sort of remember having to remove the tray from the rear storage compartment at the floor and removing the front cassette/coin tray to get at the screws. It mounts onto little tabs sticking up from the floor.
Old Mar 23, 2004 | 06:48 AM
jeff_67cougar
Thanks, do you remember how the coin tray comes out?
Jeff
Old Mar 26, 2004 | 10:45 PM
DadVan's Avatar
DadVan
jeff 67cougar,
The console is mounted with four nuts that attach through two plates to four studs on the transmission tunnel. I concur with recobardo that you must access these from the inside of the console. Remove the tray from the back AND the "fuzzy" container from the top. Both are retained with plastic "tabs" that allow you to gently squeeze the sides of each and remove them. I can't remember the exact size of the nuts, but I do seem to recall them being metric... Small hands were a big help here... The coin tray can't come out until the garage-door-opener-holder comes out which can't come out until the console comes out... You get the idea...
BTW, I know this fairly well because I've removed (and reinstalled) the consoles from a '93 AND a '97. I'm a stormchaser and install radio/computer gear on the hump using the four console studs.
Good luck!
DadVan
Old Mar 27, 2004 | 06:07 AM
jeff_67cougar
Thanks, I got her out, yes small hands help.
Jeff
danr1707
Feb 18, 2019 09:16 PM
1ole4d
Mar 1, 2017 08:26 PM
Rwloope
Feb 20, 2016 06:04 AM
DGMFORD
1997 - 2003 F150
Sep 9, 2007 08:58 PM
MrWiggly
Mar 6, 2004 11:20 PM
