Bronco II Ford Bronco II
wiring harness
Old Mar 22, 2004 | 06:53 PM
dbstotty65's Avatar
dbstotty65
wiring harness
im installing a 2.9 into an 85 b2, which of course had a 2.8 in it. ive switched over the harnesses inside and out, the only problem is the 2.9 was out of a 5 speed tranny 86 b2, im tryin to figure out the harness so i can add the neutral safety switch off of the old 85 harness, i did find that there was a jumper wire to take place of the clutch switch so i have that covered, the manuals i have dont actually show the wires, does anyone have a good copy of a harness, or know which manual has good schematics, or just a suggestion on what i should do
Old Mar 22, 2004 | 07:55 PM
Ken00's Avatar
Ken00
The neutral safety switch and the clutch switch use the same curcuit, my 1989 wiring diagram show the wire from the ignition switch as pk in/out of the jumper, pk into the NSS and r/lb out of the NSS. On a manual tranny there is a jumper were the NSS would be.
