Bronco II Ford Bronco II
noisy ride?
Old Mar 18, 2004 | 07:22 PM
waywoos's Avatar
waywoos
Angry noisy ride?
i think my throw out bearing is bad but im not sure.
when i put in the clutch the chatter goes away.
when i drive in first second third and fith gear its noisy as heck.
but i 4 th gear is quite.
is this throw out bearing or my manual transmission.
could i be getting low in gear oil?
thanks
Old Mar 20, 2004 | 07:19 PM
BroncoIIFool's Avatar
BroncoIIFool
More than likely, your transmission is toast..
I experienced the same thing with an 85, all gears save for 4th were nothing but clatter..
On a good note, she still got me home which was 65 miles away..
Get ahold of a reputable tranny shop, they can confirm for sure.. Then go to a junkyard and get a replacement..
Good Luck..
Old Mar 20, 2004 | 07:28 PM
waywoos's Avatar
waywoos
what is approx cost to have rebuilt.
or how about a junk yard one.
please let me know someone
thanks
and how much do they charge labour for job.
thanks
Old Mar 20, 2004 | 07:34 PM
BroncoIIFool
It varies state to state for labor, best thing to do is check around..
I got a good used 5spd for $500.00, but it only had 38,000 mi on it, so that may have made it a little on the expensive side..
A rebuild is usally pretty expensive + you have to make sure a reputable shop is available that will warranty their work..
Ebay may also have some used trannies you can check into..
Again, I am not POSITIVE that your tranny is toast, I am just sharing my experience(all my synchro gears were shot and if I remember right, the tranny mechanic told me that 4th was okay which is why I didn't hear clatter in that gear)..
A Tranny Pro can verify for sure though.
Good Luck..
Old Mar 21, 2004 | 06:38 PM
waywoos's Avatar
waywoos
yesturday i put new synthetic oil in transmission and after i took and hour long ride, when i was coming home and shifted from stand to fisrt gear i noticed lots of improvement. same with first to second and so on.
i can hear a little bit of clatter sometimes.
stange goes away when clutch is pushed in.
Old Mar 22, 2004 | 09:05 PM
waywoos's Avatar
waywoos
wow after driving it for a day or so the noise is almost gone
i believe im driving a new truck again.
thanks all
why would 4th gear now want to slip out real easy
any suggestions?
