Front End Noise
Old Mar 22, 2004 | 03:44 PM
smittybat22's Avatar
smittybat22
Front End Noise
For the past week or so , I've been getting a load squealing sound from the drivers side front end. Every time I move the steering wheel or go over a bump the vehicle emits the most awful squealing sound I have heard. It doesn't amek this sound at all it I'm driving straight on a smooth surface. Anybody have any idea what the cause of this might be?
Old Mar 22, 2004 | 07:26 PM
98xlt4x4's Avatar
98xlt4x4
You need to post what year ranger you have and whether it's 4x4 or 4x2. I'm going to guess that it's a 98 or newer ranger, and that the noise is a bad lower balljoint. Best to replace both lower balljoints at the same time. Replaced both of my lower balljoints now I think I might hear a little bit of noise from the uppers. 2 lower balljoints installed, probably $500 +/-. Hope you have some kind of warranty on it.
If you can make the noise by bouncing the front end when it's parked, diagnosing will be easy. Have a friend bounce the front end while you take a long handled screw driver, handle end on your ear, and the other end on the balljoints. Or use a stethescope if you have one. Good luck
Old Mar 23, 2004 | 11:20 AM
smittybat22
It is a 2001 4x4
Old Mar 24, 2004 | 12:36 AM
98xlt4x4's Avatar
98xlt4x4
Yeah, most likely lower balljoints. See if you can find a shop that will diagnose it for you without much (if any) charge. Good luck.
Old Mar 26, 2004 | 07:46 PM
smittybat22
Yeah it was
It was the lower ball joints after all. It was a good thing I had the extended warranty or it would have been a 500 repair.
Old Mar 26, 2004 | 10:31 PM
danostuff's Avatar
danostuff
Could also be tie rods, mine is doing the same thing. Sounds like a loud creaking noise.
Chasetgd
New Member Introductions
Feb 10, 2015 08:13 PM
pfb
Apr 2, 2011 08:12 AM
Screwedkid
Jun 4, 2009 06:05 PM
PSKSAM2
Aug 24, 2003 11:47 AM
