I was looking into buying a holley carb for my 460. I would probably want it in the 750cfm range and would like it to not have a choke. It is going to be on the stock 4 barrel intake so it is going to need to be a spreadbore design. Any suggestions?
The for spreadbore is a special pattern, holly does not make a carb that will fit directly without an adapter. Luckily Summit racing sells an adapter that will let you use a holley carb with the squarebore design on the ford spreadbore intake manifold design. Good luck, the 55$ is a fair price for the adapter unless you want to get a different manifold.
