Why the short stroke? You give up a ton of HP and TQ. Scatt 4.3" crank is $450
Why 15:1? Even with the Kasse head your pushing it I would think. Nothing but the most expensive race fuel. 13.5 would be better and let you run cheaper fuels like cam2 or turbo blue.
With a small cam like this, you dont really need to worry about titanium retainers. Run titanium when you are using a big lift and fast ramp...not a slow lobe and low lift. Its just wasting cash.
Titanium valves.....read above. Thats an odd combination. I would use those heads and bore that block to 4.5", use a hyd roller for sub 6500 RPM use, a 4.3 or 4.5 scat crank, a set of manley H-beams and for cam specs.....I would stay were you are for a street engine. For a all out race use I would do the cam as a .750 lift and 280 duration at .050 minimum. Rethink some of that and try agian.
OK, sorry, but the bore should be 4.500, missed a key. I change the cam to a Solid .640, .666, 260*, 270*@.050, 295*, 305* adv.
I like the compression just the way it is, and the titanium retainers and valves are for reduced rotating mass. The reason for the short stroke, big bore combo is to keep the combo under 470 cubes, the limit for the big block EM Challenge. I just want someone with Desktop Dyno to run the combo, with the revisions, and post them here, if it is not to much trouble.
I think the 3.59 stoke will be to short for your piston to get to TDC. I'm building a 467ci(468ci limit) 7.1 rod motor and had to have the crank offset ground to 3.8 stroke and they will be about .005 out of the hole. For it to really work you may have to go smaller on the bore and add some stroke. But it all depends on the pin height of your pistons.
Your only gonna have 457ci. Give me some more info and I'll run it through Desk Top Dyno.
What size carb?
What is the lobe seperation on the cam?
What kind of intake?
Headers?
110 LCA on cam
1150 Dominator
Weiand Stealth SCJ, 2 1/4 inch adapter
2 1/8 x 37 inch primary, 3 1/2 inch collector
3 inch exhaust with Dual Dynomax Bullets
Yea. I tried when I posted the numbers but I'll have to print and scan it and can't get scanner to work. I'll try again tomorrow. The torque and horsepower curve are REAL good from about 4,000-7,000.
