Sponsored by: Real Truck
Gauge info desired
Old Aug 19, 2000 | 02:31 PM
Mulepick's Avatar
Mulepick
Gauge info desired
I'm putting either a two or three pod instrument panel on the drivers pillar. I'm interested in knowing more specifically what my water temp, tranny temp, and oil pressure are.
Is it better to use electrical or mechanical gauges? If electrical, has anyone mated these up with the existing temp/pressure sensors/senders? If mechanical, what means is used for sensor placement?
Any and all info appreciated.
Bob
Mulepick(No Email Addresses In Posts!)
2000 F-250 4x4
Old Aug 20, 2000 | 05:38 PM
SuperPleased's Avatar
SuperPleased
Gauge info desired
First off, it's my understanding that Ford uses a pressure-operated SWITCH, rather than a variable resistance, to feed the dash oil gage. If that's so, you'll need to buy an aftermarket pressure transducer to feed the new oil pressure gage. And, you'd be well advised to get electrical gages, and not the mechanical type, because one little oil leak from the tubing connected to your gage would surely spoil your day!
Your local Ford dealership can answer your questions on tranny and coolant temps.
Hope this helps you.
Yom
>placement?
Old Aug 21, 2000 | 02:10 AM
V10man's Avatar
V10man
Gauge info desired
Mulepick
May 22, 2009 08:40 PM
Mulepick
Jan 1, 2001 07:49 PM
Mulepick
Sep 29, 2000 12:19 PM
Mulepick
Sep 14, 2000 08:39 AM
Mulepick
Aug 15, 2000 11:37 AM
