ABS Brake Problem
Old Mar 21, 2004 | 07:01 AM
tony01's Avatar
tony01
ABS Brake Problem
4 wheel ABS system. Replaced rotors & Pads(front) Stopping works great high speed and normal w/good solid pedal, then at speed of 15 to 5 mph the abs system engages. This is on solid dry pavement. ? ? ? Strange.
Also when trouble shooting the problem my manual says to jumper pins a to d on the diagnostic plug under the hood. this will blink out any codes in the system. Thats great, except the plug IS NOT stamped with letters. (who would have thunk that), and my manual does NOT indicate which pins are which.
Any and all suggestions would be greatly welcomed cause this one has me,,,,,,,ARG
Thanks
This is on a 96 Bronco and I've posted to that thread also, but a ford is a ford is a ford and I'm desperate.
Old Mar 21, 2004 | 11:36 PM
Talyn's Avatar
Talyn
can always just pull the positive wire off the batery for a while and let the computer reset.
Old Mar 23, 2004 | 07:33 AM
tony01's Avatar
tony01
Batt wire off to rest the computer?????????/
Did you read my post?????
I'm trying to read the fault,,,,,not rest it.
Old Mar 23, 2004 | 09:49 AM
Talyn's Avatar
Talyn
that means reset the computer.
Old Mar 23, 2004 | 12:10 PM
frederic's Avatar
frederic
Tony, What Talyn is suggesting is instead of reading the faults, just reset the ABS system completely, as 95% of the time, ABS system problems that are computer related just "go away", and you can drive for years without having a problem again.
Anytime I have to do brakework on my 93 F350, I disconnect the battery for the same reason, so the rear ABS doesn't decide to flip out.
Not sure why, its kinda like cntrl-alt-del for windows, but it works the vast majority of the time.
Old Mar 23, 2004 | 12:55 PM
EPNCSU2006's Avatar
EPNCSU2006
It's nice to find out the codes though, to find out why the light is on before resetting it. Talyn, jumping the pins on the plug does not reset the computer - it is to blink out the abs codes, so he can find out what is wrong with the truck.
