Sponsored by: Real Truck
Motive Gear
Old Mar 21, 2004 | 05:48 AM
icyford's Avatar
icyford
Motive Gear
Just got my Motive R&P for my truck. I ordered this from a store in Canada, because I bought the truck there and shipped it from there to Iceland.
I didnt specify any particular brand (should have done so) bot did specify this was for a 2004 F250 4x4. Sterling 10.50 and Dana 60 front.
Well, now that I got the R&P it turns out that for the rear axle its 10.25. (Motive F10.25-489L) gear ratio 4.89 but gear ratio for Dana 60 front is 4.88. (Motive D60-488XF)
So question to you gurus. Is it ok to use those together, i.e. 4.88/4.89.
How much weeker is 10.25 compared to 10.50.
Old Mar 21, 2004 | 09:17 AM
99f350sd's Avatar
99f350sd
Prob the same gear ratio they just rounded it off...Count the teeth to be sure..10.25 to 10.5 no difference really...Make sure you do it right...!!
Old Mar 21, 2004 | 10:14 AM
icyford's Avatar
icyford
Gear ratio roundoff
Yes I belive youre right, but always better to be sure. A car mechanic is going to install this for me, so the installation should be ok. He also has a truck him self and is use to install those.
Thanks
Old Mar 21, 2004 | 10:38 AM
tankhead's Avatar
tankhead
Re: Motive Gear
I thought after 98 rear ends came w/ a corporate 10.5" and not the sterling 10.25". I had the same question about Motive 4.89 when I was ordering gears too for my Dana 50 and 10.5". And the guy said that there would be no difference. But I'm like you. I wanted the exact same ratio. I don't know whats up w/ your Dana 60 but the application chart from Drivetrain SuperStores only lists 4.88's for it. While the 10.5" lists only 4.89's. I do like the Motive name brand though. Hope it helped some! Best of luck.
Old Mar 21, 2004 | 11:26 AM
99f350sd's Avatar
99f350sd
whats the tooth count on the R+P? 39,8
Old Mar 21, 2004 | 12:11 PM
icyford's Avatar
icyford
No its 44/9
Old Mar 21, 2004 | 12:17 PM
icyford's Avatar
icyford
If I search by axle then this one from Motive Gears is listed:
RING & PINION 4.89 RATIO - 10.25 inch gearset with adapter bearings included to fit 10.5 inch
I did not see any bearings though, but Im also installing ARB locks and it came with bearings. Mabe they just put it in that box before shipping.
Old Mar 21, 2004 | 02:30 PM
99f350sd's Avatar
99f350sd
No its 44/9
Oh yea missed that one...as long as the gears have the same teeth its the same ratio.
What bearings? pinion? I'm missing something..
Old Mar 21, 2004 | 03:35 PM
icyford's Avatar
icyford
[QUOTE]Originally posted by 99f350sd
Well, actually the front ring has fewer teeths (its of corse smaller) but so does the pinion. The front is 39/8=4.875 as the rear is 44/9=4.889.
So there is a 1% difference between rear and front. Its that difference Im worried about. Should this be ok.
Old Mar 21, 2004 | 07:10 PM
99f350sd's Avatar
99f350sd
not 1 but .5% difference by my calcs..no problem at all..
jerg_064
Ford Truck Parts for Sale
Jul 13, 2014 08:00 PM
'86 F150
1978 - 1996 Big Bronco
22
Jun 16, 2014 08:22 PM
DILLIGAF13
Offroad & 4x4
Aug 18, 2011 10:07 AM
icyford
Mar 18, 2004 06:47 PM
