Running horrible after headers install
Old Mar 21, 2004 | 08:07 PM
bremen242's Avatar
bremen242
Try looking at your plugs&wires at nite. I have a similar problem with my grand am, and I found that the #1 plug was arcing over onto the exhaust manifold. Make sure you rev it up, as mine didn't arc at an idle, but did when you revd it up.
Old Mar 21, 2004 | 08:19 PM
95 F150's Avatar
95 F150
Like I said in my original reply , it has to be a plug or plug wire problem - plug wire routing , wire problem, or like mentioned above a broken plug. I don't think a vacuum leak would cause a major problem with the way your truck is running. Some yes but not like the way you're describing.
Old Mar 21, 2004 | 08:20 PM
fordnut1985's Avatar
fordnut1985
i agree i would start with ignition
Old Mar 21, 2004 | 09:48 PM
Wakeboarder141's Avatar
Wakeboarder141
Well, I went out and misted the wires and ran it in the dark. Sure enough, the front plug on the passenger side was sparking away. It looks like the spark is coming from between the plug boot and plug maybe? It appears as sort of a ring of flash around the base of the plug. Does that make sense? What would cause that and what is the fix? Thanks.
Old Mar 21, 2004 | 10:05 PM
TheWiz427's Avatar
TheWiz427
Change the plug sounds like it's cracked.
Old Mar 21, 2004 | 10:22 PM
95 F150's Avatar
95 F150
Or the metal connector seperated from the wire. Pull the wire and inpect it. Swap the wires out on the dizzy with another wire and see if the problem is still there. You might have seperated the connector when you removed your plug wires.
Old Mar 21, 2004 | 11:19 PM
Wakeboarder141
Well I pulled the plug out and it was cracked. I put one of the old plugs in and it stopped sparking, but it still runs just as roughly. The old plug isn't in great shape, but it was working fine when it was pulled out. I will go get a new plug in the morning, but I am not confident that is the only problem.
Old Mar 22, 2004 | 12:19 PM
local boy's Avatar
local boy
Wake This really sounds like you crossed a couple of wires..... Running rough and then worse when you give it gas somes like like crossed wires on the money. If you dont have a book to check the firing order you should realy think about getting one. I cant remember how many times I scewed up putting wires back on....Good Luck
Old Mar 22, 2004 | 02:42 PM
bremen242's Avatar
bremen242
Don't feel bad. I ran 2 sets of bosch in my 300-6 without a problem, got 30k miles out of them. Same thing happend to my pontiac, after 15k miles, one cracked.
btw, did you spray the other bank to see if one of those where cracked?
Btw, on my 351W, the guy who changed the front accidently bent the electrode on one of the front plugs by accident, shorting it out. Boy did it run bad.
Old Mar 22, 2004 | 08:22 PM
Wakeboarder141
VICTORY!
Turns out when I was checking wires and found that cracked plug last night, I left the wires crossed when I was checking them! Now the thing runs like a champ with more power than ever! Thank you guys very much for all your help. I would be totally lost without it. Now to just get rid of this exhaust leak
Old Mar 22, 2004 | 08:30 PM
95 F150's Avatar
95 F150
Told ya , where is the exhaust leak coming from? , I'm sure we can help you with that.
Old Mar 22, 2004 | 08:41 PM
Wakeboarder141
I am thinking it is either because the Y pipe is not bolted on tight enough, or because of that one bolt that is sheared off in the block and thus, not holding the header on.
Old Mar 22, 2004 | 08:45 PM
  #28
95 F150's Avatar
95 F150
A sheared off bolt in the block will definately cause an exhaust leak. Hopefully it's on the drivers side, that will make life alot easier.
Old Mar 22, 2004 | 11:48 PM
  #29
Wakeboarder141
That would be nice, wouldn't it? Such is not my life, though. It is on the passenger side. Oh, well. Why fix? Upgrade! Gives me a way to justify it to the woman.
Old Mar 23, 2004 | 11:39 AM
  #30
modru2004's Avatar
modru2004
i just had headers put on my truck and i have an exhaust leak on the passanger side as well. go figure.
