Timing Gears
Old Mar 20, 2004 | 11:27 AM
stressed's Avatar
stressed
Timing Gears
Hi all, currently rebuilding a 88 351w,SD efi, I was going to use a noisy gear drive timing set, but part supplier said that the spark knock sensor may pick up the noise and through my timing off. The only reason I am using gear drive is cause I like the sound. all thoughts appreciated.
Jeff
Old Mar 20, 2004 | 12:02 PM
4x4lowandslow's Avatar
4x4lowandslow
You could pull the knock sensor out of the block, leave it connected and secure it away from the engine.
Old Mar 20, 2004 | 03:43 PM
RLKBOB's Avatar
RLKBOB
Gear drives give you more accurate timing but thay also cause your valve train to wear out quicker. No matter what the local trends are they are a bad choice for a daily driver.
Old Mar 20, 2004 | 04:00 PM
StrangeRanger's Avatar
StrangeRanger
So the 300's valve train wears out quickly? That's news to me. Gear drives are MORE durable than chains as well as more accurate. The downside is noise. The knock sensor question is a good one, often asked but never really answered.
Old Mar 20, 2004 | 10:43 PM
EPNCSU2006's Avatar
EPNCSU2006
I don't think the 351 has a knock sensor.
AJ Goss's Avatar
AJ Goss
I'll agree with StrangeRanger on this one. The 300 has a gear driven cam, and no other engine comes close to the 300 in terms of longevity.
Old Mar 20, 2004 | 10:58 PM
stressed's Avatar
stressed
no sensor?
that would be great, well for me anyways, cant find my manual
Thanks Jeff
