I doubt FTE will help or they would have to do it for every chapter. But I agree I think we can all share in the cost of the banner. It will be for all of us so let's figure a way to get the money together.
well as I said before. for a banner about 3x8 and depending on how many colors a banner made with vinyl would probably cost about 50-70 bucks. if it was to be a digital banner (full color) it would be considerably more. I run the machine that makes the vinyl banners, I design, cut and apply them. so I can do it after work with the permission of my super. the digital however is more closely monitored by higher up people. so when ever you guys come up with a design and size I can let you know what I can do. unless you find another route.
voodoo73 at *** dot net is my addy.
well a vinyl banner consists of solid colors, where you cut your seperate colors and then put them all together on the banner to make your final image. so there is no gradations and limited colors. a digital banner is printed on a huge printer right on the banner material and can have a million colors, bevels, and gradations. they can look like actual photos. if you were to tell me what you wanted on the banner I could do a mach up of a couple of different styles.
OK, the frame I have will take a 2ft.X 6ft. banner There will need to be grommets on it as well. 3 on the top and 3 on the bottom. I personally think that the on digital banner would be fine.
ok just keep in mind that digital banners are considerably more expensive. if you can make a .tif or a jpg at full size at 100 dpi. and email it to me I can see how much it will cost. if you choose to go the other way. let me know. later
Shane
