Gauge wireing
Old Mar 19, 2004 | 08:49 PM
51truck's Avatar
51truck
Gauge wireing
I am installing new Dolphin gauges , do I ground them to the dash or the neg battery post, or does it matter. Thanks
Old Mar 19, 2004 | 10:10 PM
50 Merc's Avatar
50 Merc
You should be able to just ground them to a good clean ground behind your dash as your cab should be grounded to your motor which is in turn grounded to your frame which in turn is grounded to your negative post, (Did I get enough turns in there?) Any how I'm also going to install Dolphin guages in my truck, Let us know how you like them
Alan
Old Mar 20, 2004 | 04:28 PM
51truck's Avatar
51truck
Got the gauges installed the only proublem is the fuel tank sending unit is smaller than the one on the tank. I am going to call monday to see if the have larger one.
