Sponsored by: Real Truck
Locking hubs
Old Oct 8, 2000 | 08:46 AM
bigv10's Avatar
bigv10
Locking hubs
Does anyone know if the auto/man locking hubs can still be used to engage 4 wheel drive if the ESOF vacuum pump (that normally eagages the hubs) fails? Is the manual setting a failsafe backup for the ESOF?
Old Oct 8, 2000 | 01:10 PM
SuperPleased's Avatar
SuperPleased
Locking hubs
>the ESOF?
"Yes" to both of your questions. But, remember that the transfer case gears are engaged by an electric motor in the transfer case, so your dashboard selector switch must *also* be used to engage/disengage 4WD.
You probably already know that running your rig in 2WD with the hubs manually locked can cause excessive wear, so keep that in mind.
Tom
Old Oct 9, 2000 | 10:13 PM
wildfire's Avatar
wildfire
Locking hubs
Do you know if you can put auto locking hubs with the manual txfr case?
Old Oct 10, 2000 | 08:38 AM
bigv10's Avatar
bigv10
Locking hubs
No. The auto locking hubs are only available with the ESOF. I asked the same question to my dealer.
Old Oct 10, 2000 | 11:09 AM
SuperPleased
Locking hubs
In theory, there's nothing to prevent you from modifying your vehicle to use vacuum-operated hubs with the electrically-operated transfer case.
As a matter of practicality, you should probably forget the notion. The sheer cost of replacing all those manual components with the ones needed to make the conversion will no doubt change your mind.
You maight also consider that many have chosen to replace their factory-installed shift-on-the-fly automatic system for the front hubs with the ~more reliable~ (fact) manual hubs.
It's your choice, though. One person's headache can be another person's passion.
Tom
Old Oct 10, 2000 | 12:17 PM
SuperPleased
Locking hubs
p.s.: I have ESOF, and like it! Have had some problems, but still like it.
Tom
Old Oct 10, 2000 | 05:58 PM
dan4x4's Avatar
dan4x4
Locking hubs
I changed out the automatic locking hubs on my '95 F 150 with Warn manual hubs and this combination (push button 4x4 and hubs) worked great.
Old Oct 10, 2000 | 09:26 PM
hotrodford_88's Avatar
hotrodford_88
Locking hubs
