360 CID ford?????????
Old Mar 19, 2004 | 11:26 AM
jjj_85's Avatar
jjj_85
I dont know anything about these motors. Im not even sure if they are a BB or SB, and if parts work from other engines, if so what. I aquired one of these engines for nothing and im curious. Can you build a decent running 360???? fill me in give me any info you can. thanks a million.
Old Mar 19, 2004 | 11:47 AM
jimshaver's Avatar
jimshaver
yes i am in fact rebuilding one for an old mustang... as well as others on here who haveand are doing so
Old Mar 19, 2004 | 01:38 PM
fordman428's Avatar
fordman428
a ford 360 is a big block V8, prolly around 215hp, most parts interchange from 352 all the way to a 428, a 360s stroke is 3.5 and the bore is 4.05, you can convert a 360 into a 390 by changeing the crank rods and pistons, the blocks, heads, etc are the same, you can make good power out of a 360, with a performer rpm intake, holley 650 carb and a set of headers, but while your in there you just as well convert it to a 390.
Old Mar 19, 2004 | 01:48 PM
rusty70f100's Avatar
rusty70f100
A good healthy cam and a port job on the heads doesn't hurt either.
Old Mar 19, 2004 | 02:42 PM
jjj_85's Avatar
jjj_85
So i can use regular 390 headers on this 360 ford i have?
Old Mar 19, 2004 | 03:19 PM
fordman428's Avatar
fordman428
yes u can
Old Mar 19, 2004 | 05:36 PM
talisker's Avatar
talisker
I just built up a 360 to replace the old 240 in my 1969 F100. The 360 may not be the highest power motor there is but I am extreamly pleased with the results. I put in a R/V cam and used the stock exhaust manifolds. I mostly pull loads of hay and building materials on a 20' tandem axel trailer.
