2.3 temp sensor ???????
Old Mar 19, 2004 | 09:48 AM
BigCrzyRdNeck's Avatar
BigCrzyRdNeck
Where is it and how often do they go out my guage shows nothin
Old Mar 19, 2004 | 01:54 PM
Ken00's Avatar
Ken00
I'm not real familar with the 4 bangers but I beleive its under the intake towards the rear. The one for the gauge will only have one wire.
Old Mar 19, 2004 | 05:48 PM
Vin 95's Avatar
Vin 95
The coolant tempature sensor on the 2.3L is located in the water Outlet pipe at the front of the engine.Check the resistance value of the sensor when its completly cold (50-65 degrees).it should be about 40,000 ohms.Start the engine and bring it up to operating temp (180-220 degrees f )the resistance should be lower, approx. 3,000 ohms.if the values are correct check the wire that connects to it. It sholud be approx. 5.0 volts dc.
Old Mar 19, 2004 | 09:51 PM
Ken00's Avatar
Ken00
Thanks for correcting me Vin.
Old Mar 19, 2004 | 11:11 PM
AlfredB1979's Avatar
AlfredB1979
The gauges on most Rangers show "nothin" even when they do work right.
1. Ford gauges aren't models for accuracy.
2. While you want an engine to run warm...you don't want it running soooo hot that all the hoses and wiring go crispy sooner than later.
Old Mar 23, 2004 | 04:50 PM
BigCrzyRdNeck
ok i do have a senor on the head at thr rear and it has one wire and no its not the oil i have changed that already
Old Mar 23, 2004 | 07:52 PM
Ken00's Avatar
Ken00
Like I said I'm not familar with the 2.3, take it out and see what fluid comes out, can't really hurt anything.
Old Mar 24, 2004 | 06:18 AM
Bob Ayers's Avatar
Bob Ayers
Those resistance values are too high for the temp sensor. The
resistance should be about 100 ohms at normal operating temp
(195 degrees).
Old Mar 24, 2004 | 08:27 AM
Vin 95's Avatar
Vin 95
You mean theres not a sending unit on the thermostat housing/outlet? I guess I should have asked what year is your truck? I got the location and resistance values from HAYNES manual 36071, 93 thru 2000.
Old Mar 24, 2004 | 10:09 AM
BigCrzyRdNeck
mine is 90
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
