Sponsored by: Real Truck
Custom Coil Springs
Old Mar 18, 2004 | 10:26 PM
Motown Fire's Avatar
Motown Fire
Question Custom Coil Springs
Anyone know where to buy custom made front coil springs for a 2003 F-250 6.0L PSD?? I want to raise the front about 2"-3"
Old Mar 18, 2004 | 10:55 PM
V10DoubleTow's Avatar
V10DoubleTow
Are you dead set on new coils? Daystar makes a 2" urethane spacer to go between the bottom of the coil and the I-beam. About $100. I think 2" is about the max you can go and still be able to adjust for correct camber. More than 2" and you're probably looking at new pivot and radius arm brackets or reforming the I-beams ($$$$$). Most 2WD kift kits start at 4".
Old Mar 20, 2004 | 03:49 PM
Motown Fire
I have installed a set of those for a friend on his supercrew. They worked ok but not enough lift for me, only about 1.5".
Old Mar 20, 2004 | 04:17 PM
V10DoubleTow
Maybe try the ProComp 4" kit. That way you get the radius arm and pivot drop brackets. The ProComp kits allow you to select the coil for your specific application, V8, V10, or PSD. Obviously, the PSD is the longest. If 4" is too much, you could then swap out the coils for the V10 coils to obtain your 2" - 3' lift. Regarding the Daystar spacers, the dynamics of each vehicle's front suspension is different and some will lift more than others. I got a full 2" with mine. I still think I'd try those first, especially since they're so easy to install on the SD and they're only about a $100.
For custom coils, search National spring. I think they're in the SanDiego area.
StrokiN&SmokiN
Aug 11, 2008 11:52 AM
jake47
1983 - 2012 Ranger & B-Series
Jun 23, 2007 10:53 AM
gary534
Jul 11, 2006 07:52 AM
Motown Fire
Mar 18, 2004 10:33 PM
