Performance Help for a 96 4.9L I6
Old Mar 18, 2004 | 07:53 PM
KYHossF150's Avatar
KYHossF150
My 96 F150 has 130K, hooked to a 5 spd and 2.73 gear. I drive 120 miles interstate daily, and I read about getting more gas mileage with increased air flow. I switched to a K&N filter, and my check engine light now stays on and I've lost about 2-3 mpg. Do I need to reprogram to allow for the increased air? I already run custom exhaust through a Flowmaster, and I need my mileage back, plus some if I can manage it. Any suggestions?
Old Mar 18, 2004 | 08:37 PM
BigBlockCapri460's Avatar
BigBlockCapri460
k&n filter
the filter needs very little oil
if you can feel it wayyyy to much oil .
the hot wire in the [maf] is dirty
remove the [maf] & clean the small
air bypass with carb cleaner
[mass airflow meter]
Old Mar 19, 2004 | 08:01 AM
KYHossF150's Avatar
KYHossF150
yeah, this filter was seriously oiled coming out of the package, so how do I clean this sensor? Do I disconnect the whole box, or can I just pop the sensor out?
Old Mar 19, 2004 | 01:43 PM
AlfredB1979's Avatar
AlfredB1979
Change your gearing.
2.73 are not anywhere near the best gears for keep the engine in the most efficient portions of the powerband.
3.55s, 3.73s....anything but what you've got now.
The computer will easily adjust to in airflow, but don't cheat and get the code erased the right way after you get it checked and it comes up as the MAF being gooed up.
Old Mar 19, 2004 | 04:18 PM
steell's Avatar
steell
And this is usually about 75 mph, at what, 2200 rpm or so? If you are running 2000-2200 rpm at the speed at which you usually drive, then I would certainly not suggest changing gearing.
We are talking about a 4.9L six, and not a 5.0 or 5.8 V8 here.
As far as better mileage goes, I would keep the tire pressure about 5 lbs over what the door sticker calls for, and look for aerodynamic improvements.
Get a net so you can run without a taigate, some kind of air dam under the front bumper, or even lowering the truck a little.
Old Mar 19, 2004 | 05:24 PM
KYHossF150's Avatar
KYHossF150
Oh yeah. I took the tailgate off long ago. The 2.73 works great for me, because I very rarely tow anything. Where is this MAF sensor everybody keeps talking about? In the airbox?
Old Mar 19, 2004 | 09:05 PM
jessfactor's Avatar
jessfactor
keep the tailgate on for better mileage. its proven that taking it off increases drag and it looks bad. if you want an improvement then get a bedcover, otherwise put it back on and keep it up. if somebody decides to argue this fact i'll find the links to the various tests proving this.
the 2.73's are horrable for all around driving, but great for highway. i have the same gears. if your going 55 it pays to keep it in forth. its nice to be able to go 75 and be right in the powerband. if your all highway then keep the 2.73's.
Old Mar 20, 2004 | 12:10 AM
1 bad 300's Avatar
1 bad 300
[QUOTE]Originally posted by steell
[B]And this is usually about 75 mph, at what, 2200 rpm or so? If you are running 2000-2200 rpm at the speed at which you usually drive, then I would certainly not suggest changing gearing.
I have a 93 with 3.05 gears in the rearend and at 80 I only pull 2000 rpm's.I am thinking about putting 3.73 gears in mine.
Old Mar 20, 2004 | 12:58 AM
steell's Avatar
steell
[QUOTE]Originally posted by 1 bad 300
[B]
Wow! What size tires you have on there?
I had an 85 Mustang Gt with the stock 225/65/15 (I think) tires, 5 speed, and 3.73 gears, and it was turning close to 3000 rpm at 80.
Jessfacter, I would appreciate it if you could post or PM me those links, there is an awful lot of air smacking that tailgate after it comes off the roof.
Old Mar 20, 2004 | 12:59 AM
1 bad 300's Avatar
1 bad 300
I have 235/75/15s
Old Mar 20, 2004 | 01:14 AM
steell's Avatar
steell
I have 235/75/15s
Assuming those tires are 28" tall, I ran it through a gear calculator, and it said you had a .68 overdrive ratio (and that's assuming a lock up TC and no slippage, if auto). That's using a 3.05 ratio (not a 3.08?). If you are going by the factory tach, they are not always accurate.
Old Mar 20, 2004 | 01:16 AM
1 bad 300's Avatar
1 bad 300
Well I have a sunpro tach
Old Mar 20, 2004 | 01:17 AM
1 bad 300's Avatar
1 bad 300
I'm sorry it is 3.05 gears
Old Mar 20, 2004 | 07:31 AM
jessfactor's Avatar
jessfactor
no problem. the air isn't smacking the tailgate like you think. it is designed so that a pocket of air is created.
http://www.cartalk.com/content/colum...ctober/05.html
http://truck-bed-covers.com/Tonneau_..._save_fuel.htm
its #13 on the list on this site
fueleconomy.php
here's a good one and it has a graph
http://sitemaker.umich.edu/um.gm.truck/no_tailgate
Old Mar 20, 2004 | 07:37 AM
KYHossF150's Avatar
KYHossF150
Guys, you can say what you want, but I got 2 mpg better after I took it off. I think probably the airflow was disrupted by the toolbox I installed. In a 6 3/4 bed, there's now only about 4' of room. This really made the air smack that gate.
