speed limiter
Old Mar 18, 2004 | 07:46 PM
RiveraD123's Avatar
RiveraD123
speed limiter
is there a way to bypass the speed limiter wire to the distributor? or is it even connected to the distributor? has anyone ever put a chip in their efi? if so, how did it do?
Old Mar 19, 2004 | 08:59 PM
Silver Streak's Avatar
Silver Streak
I believe it cuts out both fuel and spark. I hit mine once and the engine completely died; I thought it blew up. I'm not sure how the system is wired, but if your spedometer uses a cable at the trans tailshaft instead of the ABS ring on the diff you might be able to defeat it by unplugging the ABS sensor. If you have an auto trans you probably don't want to do this because the shifting might be wierd.
