Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Stupid compressor question
Old Mar 18, 2004 | 04:59 PM
stryder's Avatar
stryder
Okay this sounds really stupid, but if I hook two 5hp pumps up to run together, will a 5hp motor still work, or will I need a 10hp? Dumb question I know, but the pumps were dirt cheap at the auction I went to. I even scored big with one being a Quincy!
Thanks,
Stryder
Old Mar 18, 2004 | 05:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
You would need a 10 HP motor. Make sure you get a real 10HP motor not some fake HP "compressor duty" motor.
Old Mar 18, 2004 | 06:50 PM
stryder's Avatar
stryder
Thanks Torque1st!
I was pretty sure that was correct, but I've been second quessing myself alot lately. The motor I'm looking at is a farm duty class that is cont. use rated and requires 40 amps.
Stryder
Old Mar 19, 2004 | 05:24 PM
eehoepp's Avatar
eehoepp
I think you'd be better off with two 5HP motors running the two pumps separately. You can use two pressure switches - one with a higher setpoint to run the more reliable pump when the tank pressure drops a little & one with a lower setpoint to have the second pump kick in when you're really drawing down the tank.
This arrangement will draw less current, on average, than a single 10HP motor. As a side benefit, you'll have redundancy in your setup. The tradeoff, of course, is that you need two motor starters, two unloaders, etc.
Cheers,
Eric
Old Mar 20, 2004 | 12:35 PM
ford390gashog's Avatar
ford390gashog
how much were the pumps
Old Mar 20, 2004 | 02:42 PM
stryder's Avatar
stryder
I will probably stick with just one motor. It will be cheaper that way, depending on how much a new sheave will cost. It will just be easier to set up with the amount of space i'm dealing with.
Gashog: I gave a total of $175 for both pumps at auction with no motors. The Quincy was $100. I think I was the only one there that knew what it was. Still trying to locate info on the other, but my guess is a Westinghouse.
Old Mar 26, 2004 | 07:05 PM
ford390gashog
thats almost a unheard of deal , nice score
Old Mar 26, 2004 | 08:41 PM
stryder's Avatar
stryder
Yeah it was pretty unreal. It was mainly a furniture/antique/estate sale. The listing didnt even mention the pumps as being for compressors. Just said old pumps.
Stryder
stryder222
Modular V10 (6.8l)
Apr 12, 2013 10:46 AM
stryder
13
Feb 26, 2006 05:12 PM
stryder12
Bronco II
Dec 5, 2004 08:36 AM
stryder
Feb 28, 2003 05:56 PM
stryder
Dec 1, 2002 04:06 PM
