E150 Idle troubles
Old Jun 11, 2004 | 02:21 PM
nightowl_52's Avatar
nightowl_52
My problem was the idle jumping up once the temp gauge got to between the "O" and "R" in normal and would send me down the street doing 40. I need to change out the TPS and clean the IAC, but in the meantime I just unplugged the IAC and turned up the idle screw a hair.
No check engine light, and runs fine. Don't forget to pull a cable off the battery before working on either.
Old Jun 11, 2004 | 06:26 PM
pfogle's Avatar
pfogle
You really have to pull the TB to get at the TPS, just remember there is coolant in the TB so make sure you clamp the lines before removing it.
Old Jun 11, 2004 | 07:44 PM
mhg's Avatar
mhg
Remember to TEST before throwing money at something
pull the codes
then check the suspect parts with a digital VOM (volt ohm meter)
all parts are good until proven guilty
Old Jun 11, 2004 | 09:22 PM
Valkyr's Avatar
Valkyr
That's what I was afraid of - not fun to do on a van!! When you say 'clamp the lines', can I plug them (i.e. cork)? EGR valve looks just as bad to get at.
Pulled codes and counted the 'check engine' light - came up 11's for ign on/eng off.
Don't mean to hijack this thread - but the problem was just like mine - erratic idle - sorry.
Fuggrur, how are you doing with your situation? Any progress?
Joe V.
Old Jun 12, 2004 | 02:01 PM
Bartat's Avatar
Bartat
I had same problem, idle speed was very high 1800rpm or so, very poor gear changes (it thumped into gear at low speeds), been like it for a while. Changed TPS on thursday, it now runs like a dream with very smooth gear changes at any speed even got kick down now and idles real good
good luck
steve
Old Jun 14, 2004 | 12:34 PM
Babin's Avatar
Babin
My van runs ok but idle is not stable... When I look at the belt and tentionner while its running, I can see the tentionner shaking. Is it normal that the tension varies? Cleaned the IAC but nothing changed... What is the TPS?
Thanks
Old Jun 14, 2004 | 02:10 PM
cpt97M3's Avatar
cpt97M3
Thanks
TPS = Throttle Position Sensor. It tells the computer (ECM) how much and how fast the throttle is open. Evidently you have to remove the throttle body to get to the TPS. It's not a big part, smaller than the ICV.
Chris
tabijan
Feb 22, 2016 08:43 AM
jmb11969
May 3, 2014 03:50 PM
94F15094
Nov 1, 2010 02:52 PM
kirbykoon
Oct 14, 2010 05:23 PM
fourdoordemon
Jul 24, 2009 12:59 PM
