Light cylinder rust
Old Mar 18, 2004 | 03:59 PM
Goobzilla's Avatar
Goobzilla
Light cylinder rust
This is one of the cylinders on my 390 that has been sitting on my engine stand for the last 8 years. This is the only "bad" cylinder for rust. What are my options for cleaning this up? Hone? Machine Shop? Other?
Appreciate any advice you can give, thanks.
Ron
Old Mar 18, 2004 | 04:06 PM
rusty70f100's Avatar
rusty70f100
Can you feel any roughness with your finger? I've found that I can rub off light surface rust with nothing more than my forefinger or a paper towel.
Old Mar 18, 2004 | 04:11 PM
Goobzilla's Avatar
Goobzilla
It's not very rough at all. Someone else suggested a Scotchbrite pad and motor oil. Thinking about giving that a try.
Ron
Old Mar 18, 2004 | 04:25 PM
rusty70f100
Do the rings hang up when you push the piston over it? If it does, then it may be a problem. If it just goes over it like it's not there, then I'd just run it. It'd be gone within the first 30 seconds anyway.
Old Mar 18, 2004 | 04:59 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Ya I think I would just hit it with a scotchbrite soft pad and use some light oil like 3 in1..so you can see it come loose!!
And if that doesnt smooth it out...A couple licks with cross hatch hone will...{ball hone} good luck!! Russ!! Keep us posted!!
Old Mar 18, 2004 | 05:10 PM
Goobzilla's Avatar
Goobzilla
Thanks for all the input guys. I should have just dropped it in and fired it up when I built it (95 or 96). But hey , life's funny sometimes.
It doesn't hang up on the rings at all when the engine is turned, so maybe I should just leave it. Oh well, bottom line is this engine is finally getting put in whether I like it or not. I've wimped around for too long, but now it's all about ACTION!
On another note, what about assembly lube after sitting that long? When I pulled the pushrods out to pull the manifold off, the dab of assembly lube was still there and felt good. Should I tear it down the rest of the way and relube everything or just assume it's all still good? I guess all I'd have to do is pull the timing cover off and the cam out do the cam bearings, then drop the oil pan for main and rod bearings. Seems like cheap insurance to me.
Comments?
Ron
Old Mar 18, 2004 | 05:25 PM
RapidRuss's Avatar
RapidRuss
Hey Ron!!
Ya know what they say Bro.. it better to be safe than sorry!!
I think I would if it were me..If not just for the worry {factor}
One less thing you {dont} have to worry about!!
Good Luck with your build!!! Russ!!
Old Mar 18, 2004 | 10:11 PM
rusty70f100
Yeah, go ahead and re-lube the cam lobes if you want. But the moly lube is there more so things dont get scratched on assembly. Honestly I would just throw it in and fire it up. It'll be fine. Remember to break in the cam properly and everything will be fine. It sounds like you've fussed with it enough.
Old Mar 19, 2004 | 07:47 AM
tomw's Avatar
tomw
Belt? .. check
Suspenders? .. check
Rope & twine? .. check
Okay, I'm ready to ... never mind.
It should be fine without doing anything exceptional. And I promise I'm not paranoid, except about those people out to get me!
I've had a bare block that had been hot-tanked, and then left to rust. Cleaned up the bore with a ball hone.. assembled... worked fine. The lube will not fall off.
You must've done a good job to have so little corrosion. Fire it up.
tom
Old Mar 19, 2004 | 08:13 AM
rusty70f100
Tomw: Just because you're not paranoid doesnt mean everyone's not out to get you.
