My truck has the stock mirrors on it. I would realy like the ford manual towing mirrors. My question is where is a good place to buy them. Also am wondering how hard this swap would be. Any input on this would be very helpful. Thanks.
I had the Ford sport mirrors and bought the Ford towing mirrors that extend out. I got mine off Ebay for $110 for the pair, pretty cheap considering dealers want $300 or more for both. They were power mirrors and heated as well.
They are very simple to change. If they are power mirrors, you'll have to take off your door panel to unhook the wires inside the door. There are just four nuts you have to take off in the front corner of the door. Pop off the plastic that covers them, pull the rubber plugs and there may be some tape covering the back two, just pull that off and you can swap them quick and easy.
It's well worth it, they look better and provide a lot more visibility behind the truck.
Good luck!
