preheater
Old Mar 18, 2004 | 03:36 PM
Ford15926's Avatar
Ford15926
preheater
i was wondering if their are any pre heaters for the 6.9 diesel and if there is who makes them?
Old Mar 18, 2004 | 06:02 PM
bilder12's Avatar
bilder12
If you are talking about the block heater, you can go to an International dealer and tell them what you want. Also there are aftermarket types available at something like NAPA stores that you could probably put inline .. either lower rad hose or heater hoses. Hope this helps you out
Old Mar 18, 2004 | 08:18 PM
rancherman84's Avatar
rancherman84
you can get block heaters at napa as well,not sure about the 6.9,but on my 7.3 it mounts above the starter on the passenger side of the block.or do you want a air preheater?,if your gloplugs are working correctly all you should need to get her running is the plugs and blockheater if its real cold.
Old Mar 18, 2004 | 09:21 PM
7.3 sled's Avatar
7.3 sled
Heater
I got my block heater at NAPA . The new one comes with explicet(?) directions and even came with a new plug in harnes!!
Old Mar 19, 2004 | 09:43 AM
redneckmechnic's Avatar
redneckmechnic
i can get mine going in 35 below weather as long as its got a piece of card board over the grill to keep the wind out. we cant plug in here at school kinda sucks. never have to cycle glow plugs hit once and crank for about 3 seconds and shes off and running.
Old Mar 19, 2004 | 03:38 PM
Ford15926's Avatar
Ford15926
no what i was talkin about a supplement to the glow plugs. something that heats the air before it enters the cylinder like dodge uses.
thanks
Old Mar 19, 2004 | 04:21 PM
Adam Radloff's Avatar
Adam Radloff
Why?
Old Mar 19, 2004 | 08:25 PM
rancherman84
yeah,why?
Old Mar 19, 2004 | 09:28 PM
redneckmechnic
the reason why would be easier starting problem is yad need to heat such a volume of air to make it have a difrence ya wouldnt have an battery left to crank the engien over.
Old Mar 20, 2004 | 05:20 AM
Adam Radloff
But when these engines are operating normally and you plug them in they don't need it.
Old Mar 20, 2004 | 10:31 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If everything is right, glow plugs, fuel, starter, batteries, you do not even have to plug in then unless it is real cold.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
