4.10 gears
Mar 18, 2004 | 02:35 PM
4.10 gears
Okay,
Whats the deal? Am I the only person on here that has an Excursion 6.8L 4x4 XLT with the 4.10 gears?
Is this some kind of mishap on my part?
So how many of you other X owners have the 4.10 gears?
Thanks
Big Mick
Mar 18, 2004 | 03:28 PM
Mar 18, 2004 | 04:08 PM
Sure didn't come from the factory! How do you know you have 4.10 with a V10?
When you are ready to sell, let me know.
Mar 18, 2004 | 04:56 PM
isnt this an option b4 you purchase? well if its special ordered
Mar 18, 2004 | 06:07 PM
Nope.
4.10s only are availbable with the 5.4L
Mar 18, 2004 | 08:26 PM
I assumed mine was also a 4.10 and I have the V10
The diff tag reads as follows:
S 410 A
73 10 5 9L05
Mar 19, 2004 | 09:57 AM
S 410 A
73 10 5 9L05
Same as mine,
I must be wierd...
Big Mick
Mar 19, 2004 | 11:41 AM
After posting my response I did a little searching and found that we have the 3.73. The first digits on the bottom numbers indicate ratio.
Mar 19, 2004 | 12:48 PM
Okay, I'm lost
Heres what my door tag says...
137
K
E
CG
NOA
UTC
OL118
13
YZ
From this I gather that my Axle code is "CG" but what does it mean?
Big Mick
Mar 19, 2004 | 07:00 PM
Chaeck the tag on your axle. Top right of the differential attached with one of the cover bolts.
Mar 19, 2004 | 10:11 PM
I bet you got's a 3.73 or 4.3. No 4.10's from the factory for the V10.
Mar 20, 2004 | 12:53 AM
what was the difference again between the 410 and 373 ? sorry i keep forgeting what their purpose's are...... i know its for towing and mpg but exactly not to sure........
Mar 20, 2004 | 03:20 AM
The number denotes the rear end gear ratio.
3.73:1 and 4.10:1
The first number (before the : ) is the amount of turns the drive shaft turns to ONE turn of the rear wheel.
The lower the number the steeper the gearing.
4.10:1 will make your engine turn at a higher RPM for any given speed versus the 3.73:1.
Steeper gearing can allows you to tow larger loads without undue strain to the engine and tranny (versus 3.73) and are generally stronger due to less teeth in the ring gear for the same ring gears of the same diameter. In this case, 10.5".
Mar 23, 2004 | 03:12 PM
The tag on my axle is as follows...
3 S 410 B
.73 10 2 0A19
Now I assume this means I've got 3.73 gears. what do all the other numbers mean?
Big MIck
EXFactor
Mar 26, 2023 10:00 PM
Daleksandrovich
Mar 22, 2014 09:37 AM
Farmall05
WTB - Parts & other
Mar 9, 2012 05:31 AM
KillerF250
Sep 19, 2004 02:27 AM
4x4chevette
May 11, 2004 07:20 PM
