Cleaning a 9"?
Old Mar 18, 2004 | 12:36 AM
illuminance72's Avatar
illuminance72
Question Cleaning a 9"?
I am changing out my 3.00 center section for some 3.50's. Changing carriers completely. I want to clean out the 3.50 carrier before I install it....What do you recommend? I don't want to use a solvent that could be harmful to any rubber seals, if there are any. Should I use something like brake cleaner to get the case all cleaned up? The carrier is complete with ring and pinion and I am not going to break it down.
Old Mar 18, 2004 | 12:49 AM
freak98's Avatar
freak98
The carrier itself has no rubber seals.The only rubber seal on a 9" is the seal for the yoke.I just soakm the whole unit in my parts cleaner.
