head gasket problems?
Old Mar 17, 2004 | 06:44 PM
therigwelder's Avatar
therigwelder
my truck is runing bad i thought it was a fuel problem,however i checked compression and found #1 had no compression,#8 had 30lbs,#2 had 90lb,#4 had 95lb. the remaining four had 115-130 lbs.since i have bad compression on both sides i cant see both head gaskets blown but i could be wrong. i have good oil pressure,it smokes a little bit not enough to say its ring trouble,dosent overheat.i think i hear something knocking on acceleration.
the truck is a 96 f350 5.8l efi. what you all think ?broke rods,bad head gaskets,broke cam ?
Old Mar 17, 2004 | 10:09 PM
RLKBOB's Avatar
RLKBOB
Sounds like blow by, rings are going. Are you getting a lot of oil soaking your breather filter?
Old Mar 17, 2004 | 10:58 PM
fordeverpower's Avatar
fordeverpower
rigwelder your motor is in very bad shape or you have been using a push in style compression gauge. You could get new headgaskets but that might not solve much. Having 0 compression in #1 is most likely a broken or stuck vavle.
Old Mar 18, 2004 | 09:56 AM
therigwelder
re: head gaskets ?
its not blowby, and i did use push type guage .i know they arent accuratebut they gave me an indication that something was wrong in four of the cylinders. i am going to tear the top off today and see what things look like
lisagoud
Oct 1, 2014 08:30 PM
Slingnsteel
Modular V10 (6.8l)
28
Jun 21, 2013 07:39 PM
Ikester
Nov 25, 2006 08:04 PM
tjc transport
Jul 1, 2006 01:43 PM
falcon_slow
23
Mar 7, 2006 06:00 PM
