Sponsored by: Innova
How do i get these darn panels off
Old Mar 17, 2004 | 02:55 PM
RCOAPSTICK's Avatar
RCOAPSTICK
Ok i have gotton the three panels off necessary to put in both right speakers and the front left speaker. The back left panel in my 97 F-150(3rd door on the passenger side, no 4th door) just wont come off. Its loose and i have gotten all the buttons that hold the panel on out. It moves arround but it seems to be stuck on something. does anyone know how to get it off so i can install the 4th speaker?
Old Mar 17, 2004 | 03:58 PM
wickymustang's Avatar
wickymustang
you have all screws removed, all plastic "pop rivets" free from the frame? Then take a long flat head screw driver and gently, GENTLY fish around in there, and pry where you think it is stuck, this is how my uncle's custom shop does it, and he has yet to break a panel
Old Mar 18, 2004 | 11:39 AM
olie's Avatar
olie
If it's the passenger side, you also have to take off the two screws holding the wing window latch in place. Then you left the panel up as it has several "claws" holding the panel to the door frame. If it's the driver's side, more work is involved. I ended up having to take the back seat off of the wall and remove the pop rivets from behind it. I have the '97 tech manual on CD which will walk you through everything, e-mail me and I will be happy to send you a copy of it or help in any other way I can.
Old Mar 19, 2004 | 04:20 PM
RCOAPSTICK's Avatar
RCOAPSTICK
i cant email u for another 26 days(b/c of the way the site is set up to avoid spammers) but if u check back to this post again i would like help with getting the panels of the dash off
Old Aug 13, 2004 | 03:20 PM
bigmack's Avatar
bigmack
I am about to replace all 4 speakers on my 98 excab lariat f150, I need help with the door panels. I have power windows and door locks if this makes a difference. Please help!!! I have never done anything mechanical to my truck before and this scares the he!! out of me... I don't want to break anything...
mojo79
Nov 22, 2010 01:13 AM
97-F150-97
Apr 19, 2010 05:40 AM
captandy
Nov 27, 2009 11:01 AM
03rangeredge
1983 - 2012 Ranger & B-Series
Feb 20, 2004 11:54 PM
jayhawk137
Sep 21, 2003 10:53 AM
