Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Sandblaster
Old Mar 17, 2004 | 09:03 PM
CRJ900's Avatar
CRJ900
o thanks. well i might as well rent a bigger compressor.
Old Mar 17, 2004 | 11:33 PM
rebocardo's Avatar
rebocardo
You can buy cheap ones almost anywhere including at Autozone and much nicer ones through NAPA. The ceramic filter does a good job of catching rust and stuff too.
You might consider ditching the sand, because of health issues, and using another media. I have used Black Beauty (slag type sand) before, some Home Depots sell it, some do not.
Sounds like you have too much sand blaster and not enough compressor. If you are doing small things such as heads, a small 2 pound hand held will be enough. Lay it on a tarp, blast it, pick up the tarp and run the slag through a sieve and reuse it. A 50 pound bag will go a long way.
Old Mar 18, 2004 | 01:31 PM
just_brian's Avatar
just_brian
Here some things I've learned...
Your better quality sandblasters will have a chart showing you exactly how much psi and cfm you need to blast x number of square feet of surface area.
Use an abrasive designed for sandblasting, not "play sand" for the sand box.
Use protective equipment - A hood, eye protection, filter mask and gloves.
And as already mentioned here, dry air and dry abrasive are critical.
Also, if your blasting out in the open make sure you are well away from anything you don't want contaminated with the abrasive. The abrasive can get airborne and travel a good distance and end up in places you don't want it.
If you primarily do small projects look into a blasting cabinet.
Of course we're all on a budget, but tools are something I personally refuse to go cheap on.
Old Mar 18, 2004 | 02:53 PM
Torque1st's Avatar
Torque1st
Posting Legend
There are several threads here on sand blasting materials, equipment and SAFETY! Use the search function to find them.
6863m
Apr 22, 2011 10:55 PM
young66
Oct 11, 2010 09:45 PM
stealth1
20
Apr 30, 2008 05:27 PM
pitbulls20
Feb 6, 2008 11:44 AM
sancochojoe
Mar 22, 2005 05:07 PM
