towing 5th wheel camper
Old 03-17-2004, 08:26 AM
pdoubleop's Avatar
pdoubleop
pdoubleop is offline
I have a 79 f250, 351M-C6-3.07 dana 61. It's only got 59k miles on it. The tires are 245/75/16. I want to pull a 27' fifth wheel camper that weighs 5k lbs. What would you suggest I change to help get some more power for pulling? I think I'll have to do something with the gear ratio.
Old 03-17-2004, 11:17 AM
fellro86's Avatar
fellro86
fellro86 is offline
gears first, definitely. somewhere between 3.54 to 4.10, depending on how hard you want it to pull, and what kind of fuel mileage you can accept when running without the trailer. The higher the number ratio, the more the engine has to spin, and the more fuel you can expect to use.To pull best the 4.10 would be best for highway use, the 3.54 will not have as much pulling power, but a little better fuel mileage running by itself.
Old 03-17-2004, 11:24 AM
pdoubleop's Avatar
pdoubleop
WHAT ABOUT A 3.73?
Old 03-17-2004, 10:10 PM
SoCalDesertRider's Avatar
SoCalDesertRider
SoCalDesertRider is offline
3.73 is a descent compromise between mileage/freeway speed and towing power, provided that you stay with stock height tires. With a Dana 61 not being all that common an axle these days, I don't know what your ratio choices will be.
I wouldn't suggest 3.54 for towing.
4.10 would be the best but since you dont have overdrive, if you like to drive fast on the freeway you will be using more gas. I had 4.10's in my old dually with 454 engine and TH400 auto (no OD). I didn't make a habit of driving fast with it.
Old 03-18-2004, 08:21 AM
fellro86's Avatar
fellro86
fellro86 is offline
I agree, 3.73 would be best, just wasn't sure if it is available. 3.54's work, but it dogs it pretty good on the steeper hills. My father's diesel has them, and it does the job, but works it on the bigger hills, wouldn't want to try any mountains though. 4.10's give the best pull and retain some highway useabilty, but the rpm's come up above 3000 trying to run 60 or more.
Old 03-22-2004, 08:48 PM
fordnut1985's Avatar
fordnut1985
fordnut1985 is offline
i have a c-6 in my 79 f-150 and my brother swaped 1st and 2nd planetarys out of an e4od (i think) and i got about 11% underdrive in first and second while keepind my final ratio the same so it didn't effect my milage. It made a BIG difference pulling my car hauler from a stop, and with 3.73's it still ran well at highway speeds.
Just my 2 cents
Old 03-27-2004, 09:12 PM
ljbrown's Avatar
ljbrown
ljbrown is offline
Just wondering... I went from a 97 F150 5.4 Auto reg cab to a 04 F250 same specs. The 97 w/373 rears pulled my 27' fiver just fine. A tad slow on hills. I aint hooked on yet but I'm thinking that the 5.4 in a 250 might be enough mill to haul as good as with the 150 . GVW of the 97 was 5373 the 04 is GVW 6575 these are certified weights taken on the same scales. Any thoughts??
Old 03-27-2004, 10:44 PM
SoCalDesertRider
If the '04 5.4 is equally powerful as the '97, and the new truck weighs more, it would be similar to pulling a trailer that weighs 1200 lbs more with the old truck... So basicallly, no, the new truck will not pull as well as the old one (engine output, transmission, axle gearing, and tire size being equal). Tire size is another thing, your new 3/4 ton may have taller tires than the 1/2 ton. For pulling with a 3/4 ton and stock tires with an overdrive trans, 4.10's are best.
Old 03-29-2004, 07:26 PM
ljbrown's Avatar
ljbrown
ljbrown is offline
Thanks SoCal; You reaffirmed what I imagined. I do have the 4.10 tires but not much more. I have been told the '04 5.4 has a tad more berries that the '97 but me thinks that will be lost in the 250. I'll just have to give it a try and see what adjustments I can make. Thanxs for the input
Old 03-29-2004, 08:34 PM
doccamel's Avatar
doccamel
doccamel is offline
Contrary to what other people may tell you, size does matter. If you have concerns about power get a bigger motor. problem is resolved. If you go diesel you may be able to even get good mileage to boot.
Old 03-29-2004, 09:44 PM
ljbrown's Avatar
ljbrown
ljbrown is offline
Thanx Doc: The Diesel is sounding better. No pun intended.The V10 is a bust. Excuse me for looking at 6.0 in the GM site. What is my punishment
Old 03-29-2004, 11:32 PM
SoCalDesertRider
No punishement here, all 3 manufacturers make good trucks and engines. I just prefer the Blue Oval...
n1bnc
1999 to 2016 Super Duty
01-15-2013 09:21 AM
mxnick824
07-16-2010 12:20 PM
burncoat
12-08-2009 10:38 PM
elmo8641
52
09-05-2007 11:34 AM
dragula
Fifth Wheel & Gooseneck RV Towing
01-08-2005 08:45 PM
Quick Reply: towing 5th wheel camper
