Leaky Valve Cover Gaskets
Old Mar 16, 2004 | 09:32 PM
Rads 79's Avatar
Rads 79
As you pop the hood and look at the engine, back on the left hand corner of the engine, my valve cover is leaking.
I am going to attempt to tighten it, but it is in a terrible spot. The heater blower is right by it. If I would decide to replace the gasket because it won't stop leaking, even if I can tighten it, do I need to remove the blower in order to work on it properly, or is there another way to accomplish this task without the extra work?
Or is there an easy way to tighten the bolt in the back...???
Maybe a couple of long extensions???
Old Mar 16, 2004 | 09:36 PM
fordman428's Avatar
fordman428
you should be able to work around the heater blower, no need to take it off, long extension should do the trick. good luck
Old Mar 16, 2004 | 10:22 PM
Colo79Ford's Avatar
Colo79Ford
I think i did the corner bolts with a stubby wrench instead of a socket.. if i remember correctly..and it has been 1 year...still not a single leak..first new valve cover gaskets i ever replaced too...Hopefully that helps some...
---JOHN
Mike in Ohio
Nov 27, 2012 09:39 PM
Aggie05
1983 - 2012 Ranger & B-Series
Oct 9, 2008 09:09 PM
Truxx1956
Jan 25, 2008 09:41 PM
joezee
Jan 15, 2003 05:10 AM
gt bronco
Dec 8, 2002 06:35 PM
