Reason for NOT buying CHEVY
I just wanted to hear some of your reasons for not buying the new Chevy Heavy Duty truck. I am a big Ford man, and I figured I'd pull into the Chevy dealership with my 2000 F-350, Crewcab, Lariet, 4X2, and go and take a look at the new "Heavy duty" trucks from Chevy. Well my main reason for never owning one, is because Ford has done me well, but also, the new Chevy's are TOO SMALL! I couldn't believe it, my head hits the roof. Now, I am 6'8" tall, and i have a solid 4" above my head yet, and i find the driver's seat in the chevy too cramped, everything is built too tight. Anyway, i just wanted to hear some of your guys reactions to the new "H.D" trucks from Chevy, and what you thought. I'll keep my Ford over a Chevy ANYDAY!!!
Mark
All of the vehicles we've owned (both Ford and Chevy) had good engines and tranny's that lasted well over 100k miles..
So naturally, every vehicle I've personally owned have been/still are Fords. They've always treated me well..
I bet Chevy is also capable of making good trucks, but why should I switch from Ford?
thanks
Murph
Enter the Chevy. The Chevy chained up all four wheels and began towing the trailer. On top and in the snow, one of the cross bars on one of the Chevy's rear chains broke loose. As the cross bar whipped around, it wrapped around the fender cross brace that runs from the cargo box to the outside bottom of the rear fender just aft of the rear wheel. The chevy owner thought he was getting stuck so he gunned it (high rpm required for torque). When he did this, he torqued the entire cargo bed and rear fender ($700 fix). (Note that the Ford unlike the chevy or the dodge has a protective plastic sheet which protects this brace from sticks, loose chains, or whatever)
Enter my new 2000 F250 SD SC 5.4L auto 4x4 Lariat. I chained up and bailed them both out. Because their outfits were busted, they also got to ride in the Ford and were impressed by the low RPM torgue of the 5.4L in the heavy snow and the general truck finish. It is a fine looking machine.
As both the dodge owner and the chevy owner put it, "I'm buying a ford next time."
True story!
NEWB V10
Daywalker
92' F-250 351 4x4 xlt 4.10 5spd sprcab lngbed
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
toydestroyer1(No Email Addresses In Posts!)
>vehicles we've own'd seemed more
>solidly built than Chevy. Body
>panels of the Fords didn't
>rust, the interior held up
>better to normal wear and
>tear without developing squeeks and
>rattles, the steering/suspension seemed to
> required less maintence (tires
>lasted longer, alignment lasted longer
>before needing re-aligned, steering always
>was solid.
The BIGGEST reason not to buy a new ford is the whole firestone issue. Why would you continue to support a company that knowingly killed people?
>well..
>why should I switch
>from Ford?
Because they aren't know for killing people to save a few bucks.
>on the continental divide between
>Montana and Idaho. We
>(three outfits: a dodge, chevy
>and my ford) were in
>a blizzard and about 18"
>of snow had fallen.
>A heavy duty cummins diesel
>dodge was pulling a small
>trailer and had a load
>of gear (4 wheelers, tents,
>stoves, etc.). The dodge's
>4 wheel drive went out
>and he jack-knifed his rig
>with the trailer even with
>all 4 wheels chained up.
> Seems diesel had dripped
>down on the electic vacuum
>operated servo that engages the
>front hubs and dissolved the
>rubber bushings. No vacuum
>= no 4 wheel drive.
> (Note that the Ford
>has a manual hub for
>just this situation and, also
>when you get stuck in
>2 wheel drive before the
>wheels turn to hook up
>the auto hubs)
> On top and in
>loose. As the cross
> I chained up and
>time."
>True story!
um, sure
The quote:
end quote:
Ford did not kill people, not knowingly or otherwise. Beware of media hype creating news rather than reporting news..
If you truely believe that Ford did this, then you'd also believe that you should not buy chevy trucks either.
Remember back when chevy had the fuel tanks on the outside of the framerails, which during a side impact would leak? Resulting fires left many people dead..
We know for a fact that the media overhyped that situation, they tried numerous times to create a test situation which would cause an explosion because they wanted to show that clip on TV. However, they couldn't do it, so they had to place an extra device in order to create the fire..
Also what about the issue with some chevy cars would blow up if hit from the rear. Or the Dodge caravan that would eject the rear occupants out of the van on a rear impact.. The list goes on..
All of the vehicle makers have been blamed for causing deaths at one time or another.. Its what happens when you mix the media and lawyers looking to make ratings and money..
So, by your standards you should walk to work..
Sorry 400 HP, this was for Roger B.
John Floyd
South Mills,NC
'86 F150 2wd 300 6
Crane Cam 260/272
stock manifolds, w/ staight pipe
