I am looking for a good and easily accesible pass through point from the engine compartment (drivers side) to the cab. I need to run a few wires from my fog lights to the cab and can't seem to find one. Any one have any ideas?
Try the soft rubber gromett just to the left of the break pedal where the shifter cable and a vaccum line comes in,just push your wires through beside the cable.You should be able to get to them just under the brake booster in the engine compartment.
Yeah, i was gonna say that or get out the drill, and start drilling. Otherwise if you do some unscrewing of panels, you can pull your carpet up and there should be a few rubber plugs you can remove and route your wires through there. Just look under the truck and see what you can find. This way is probably going to be more work than the above post
