clutch/pressure plate
Old Mar 16, 2004 | 03:10 PM
duback66's Avatar
duback66
I have an 89 f150 2wd with a 300 I-6 and a 4 speed that I am converting to 4wd. The donor truck that I have aquired is an 87 4wd that had a 302. the clutch and pressure plate was taken off of the 4wd prior to me getting it. I know the 300 will bolt to the trans. (at least I hope) but can I use the clutch and pressure plate that are on my 2wd with the new setup? thanks
Old Mar 17, 2004 | 11:00 AM
loudfords's Avatar
loudfords
Yes, just double check the spline count on the clutch to make sure it matches the input shaft.
Old Mar 17, 2004 | 02:07 PM
duback66's Avatar
duback66
Thanks a bunch.
