10K Mod ?
Old Mar 16, 2004 | 09:27 AM
SBFD8's Avatar
SBFD8
Lightbulb 10K Mod ?
I searched but I could not find anything but what do you need and how do you install the 10K mod. Thought I might try it to see the difference. Thanks
Old Mar 16, 2004 | 10:18 AM
Go Aweigh2452's Avatar
Go Aweigh2452
look three pages back for hcclimber and "10K question". Links and all your ques will be answered.
Old Mar 16, 2004 | 10:42 AM
99f250's Avatar
99f250
https://www.ford-trucks.com/forums/s...hreadid=210632
Old Mar 16, 2004 | 03:21 PM
coachhomer's Avatar
coachhomer
was doing research on this deal and i noticed that there are two mods... the original 10k mod, http://www.forgotton.net/mods/index.html
and a modified version,
http://forums.ford-trucks.com/ubbthr...5&o=31&fpart=1
which is better and or easier to install?
scott
Old Mar 16, 2004 | 03:35 PM
mjwhip2's Avatar
mjwhip2
After reading the "modified version" I came to the conclusion that the original is by far easier for the average person to accomplish. I did the original. cost me $1 for 5 resistors at radio shack. I already had wire, solder, heat shrink, and electrical tape so in essence, I paid $0.20 for the mod. Took about 15 minutes to build (10 minutes was looking the heat shrink, ok, where's my heat gun, where did I put that soldering iron, etc) Then about 1 minute to install it on the truck. Couldn't have been simpler. Well I guess it could have if I wasn't a slob and knew where my tools were. Try the original first, cost you a dollar, if you are satisfied keep it, if not, try the modified. Either way you wont be out much time or money.
Good luck
Mike
Old Mar 16, 2004 | 04:42 PM
SBFD8's Avatar
SBFD8
Thanks Guys, I already installed it got the resistor from radio shack piece of cake to do and install. Made a difference in power seems like the throttle is quicker idle is a little higher but it seems to go down to normal sometimes and I am checking the milege but so far just around town it is up per the mpg gauge.
Thanks Al
Old Mar 17, 2004 | 09:01 AM
SBFD8's Avatar
SBFD8
It's amazing what that little resistor will do I drove about 150 miles yesterday and the milage increase was about 4 mpg.
Thanks
Old Mar 17, 2004 | 03:36 PM
spitball's Avatar
spitball
I read in an earlier post that it made the diesel have a rough idle, has anyone found that and what is does anyone think that it would effect the longevity of the motor? Sounds like a cool mod, but are have any ill effects been noticed?
Old Mar 17, 2004 | 08:31 PM
ROK31_99PSD's Avatar
ROK31_99PSD
Spitball- As far as the rough idle goes, it does increase your RPMs by about 150-200 and sounds like it has a chop (or big cam) when idleing down. I have found that it settles back down when you come to a complete stop after a second or two. It will give you a better throttle responce and "feel" like it pulls harder. As stated in other posts in this forum, it does wonders for a stock truck but has little to moderate effect on chipped trucks. Hope this answers at least one of the questions. Peace...
Old Mar 18, 2004 | 04:34 AM
spitball's Avatar
spitball
Thanks there rock. Been interested in the mod, just like to gather some info before jumping into it. I like for the truck to perform, I want it to last also.
