Valve Spring
Old Mar 16, 2004 | 12:38 AM
1979meangreen's Avatar
1979meangreen
Valve Spring
I am in the process of rebuilding my 400 and am putting a larger cam in it. I have been told that 400 valve springs are weak. I already have a set of rebuilt heads vith stock valve spings. Should i run this or put stronger springs in it. I am planing on running a Edelbrock Performer-Plus cam shaft.
Cam Specifications:
* Advertised duration: 282 intake/292 exhaust
* Duration at .050: 204 intake/214 exhaust
* Gross valve lift: .484 in. intake/.510 in. exhaust
* Lobe separation: 112 degrees
* RPM range: Idle to 5,500
Old Mar 16, 2004 | 01:46 AM
Bill_Beyer's Avatar
Bill_Beyer
Well I hate to shoot down another myth about the 400 but their valve springs are no better & no worse than any other springs FoMoCo put in their V8 engines.
However you still should replace the valve springs if you're going with that cam. IIRC Dave R. (BubbaF250) calculated the maximum lift you could run with stock springs on a post some time back and it came out to just under .500" before they went "solid" and you start bending pushrods. I'm sure E'brock recommends a specific spring for that cam. You might check on their website.
Old Mar 16, 2004 | 09:10 AM
beartracks's Avatar
beartracks
Springs are cheap and easy to change. Just check the installed height. Bind should not be a problem but you might well see vavle float at higher rpm's.
SCRebel
1997 - 2003 F150
Dec 28, 2013 09:56 PM
CowboyFromHell
Apr 22, 2009 11:08 PM
umdstang
Mar 31, 2004 12:59 PM
jwtaylor
36
Dec 23, 2003 09:15 AM
Vgengooms
Mar 22, 2003 10:58 AM
